Question about Canon PIXMA MP210 Photo All-In-One Printer
Wont print with only a black cartridge
I have a black cartridge in the printer and the colour one has ran out, i only want to print something with black ink but it wont let me, do i have to have both full cartridges or can i just have the black one in?
    Sergeant:
  • 284 Answers
Yes you must insert both black & color cartridges in order to operate properly.
Posted on May 28, 2010
silly girl
  • 513 Answers
SOURCE: colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
Posted on May 24, 2006
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
  • 2692 Answers
SOURCE: Epson DX8400: how can i get it to print black only
Sorry Desperate. All inkjet printers, from all companies,  are programed to only operate with ink in all containers to avoid other problems. Their is no workaround. Please rate me not harshly just  because you don't like the answer. Rate based upon the truth of an answer.
Posted on Mar 11, 2009
  • 116 Answers
SOURCE: Black ink not printing
replace print head assembly
Posted on Aug 02, 2009
  • 164 Answers
SOURCE: Coloured printer with black not printing?
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Can ip1300 print with just black ink cartridge?
AS far as I know you cannot put a black cartridge in the place of a colour cartridge it has to be a colour one. Check your printer properties to see if you can set your printer to work in black only, if you can then set it to black but leave the empty colour cartridge in place. This works for my 1800. Give it a try.
Aug 05, 2009 | Canon PIXMA iP1300 Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Kodax Eps-5 Printer want print with one cartridge
No you need functioning colour cart for black to work.
Apr 28, 2009 | Kodak ESP 5 Printer
Is there any way to print without using black ink?
All hp printers need both cartridges installed to operate, it can be emty, as long as its installed. Goto prefrences in you printer settings there is a option use colour or black only.... Hope thise solves your problem
Dec 08, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
My printer wont write, it only prints out the images and colour
Here's the fix for the black not printing...Take the black ink cartridge out and punch a hole in the round dark circle at top right of cartridge with an ice pick or something sharp. Blow in the hole and make sure you have something under it just in case the ink starts dropping. Clean the bottom and put it back in and it should work.
Aug 31, 2008 | HP PSC 2410 All-In-One InkJet Printer
I keep getting cartridge error or it prints a blank page. There is no tape on the cartridge and they are installed properly. It prints sometimes but not all the time Printer keeps saying cartridge error
This has been just happening with me aswell - I just changed the colour cartridge with the black cartridge ran out but i kept it in as it told me to place one in. Trying to print out but black ink wont come - just blank pages - surely the colour cartridge can make black? However, if you have the colour cartridge and are on microsoft word or similar, change the colour of the writing to dark navy and it will print out documents.
Aug 26, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
191 people viewed this question
old marine
old marine
