Question about Ryobi Cultivator
The pull cord is stuck?
I have a Ryobi Cultivator a 700r and the pull cord is stuck what should I do?
    Problem Solver:
  • 6 Answers
Take the flywheel cover off and see what has it stuck.if it is the square nut that the rope pulley goes on the it needs some oil put in the hole on the end of it.it should turn to the left and not turn without turning the flywheel to the right.once you have it where it will turn easily to the left it should pull the pull rope back in after the engine cranks.if the flywheel won't turn to the right then you have a locked up motor.
Posted on May 28, 2010
31cc 700r curved shaft string trimmer binding flywheel and cord rewind during reassembly
as you put it together, pull the handle a bit so the recoil starter fingers fit into the flywheel as they should
Aug 18, 2015 | Ryobi Garden
Need part for ryobi trimmer no.700r
There are parts and part number listed on page 20 of the manual. Here is the link for the Ryobi 700R trimmer manual.
Jan 07, 2013 | Ryobi Garden
Model 60520 cultivator. Pull cord is fully extended and won't return. How do I get it to rewind?
I have a RY60512 and it did the same thing I removed the starter housing assembly and sprayed the inside with a lot of WD40 and worked it around and manualy rewound the cord by sticking a small skinny screw driver into one of the molded holes and just kept working it untill it started to rewind. I discovered that it filled up with water and the spring got rusty it takes a little bit of doing but finally got to work .also there are two spring loaded dogs that catch on the engine that needed to be WD40 as well. through research I discovered that the starter housing assembly is the same for both models and are still available.
campingpepere
Apr 22, 2011 | Ryobi Cultivator
I have a Ryobi 700R trimmer - I need to know how to replace the pull cord - Tom
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case:
1. Disconnect the shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts).
3. Pull the cord until the stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
Use proper line and reverse for new line. Good luck!
Aug 31, 2010 | Ryobi Garden
I HAVE JUST UNPACKED A NEW RYOBI TILLER BUT WON'T START. NEW GAS MAYBE FLOODING FROM LEAVNG IN START AND PULLING THE START CORD FOR SOME TIME?
yep...take the plug out...pull it 5 or 10 times to clear the gas...dry off the plug....re-install...hold the trigger wide open...and pull...
if that worked, go back and review the start procedures
Apr 18, 2010 | Ryobi Cultivator
Spark plug wire on Ryobi 700r broke. How to
Spark plug wire on Ryobi weed Eater broke off. How do you fix it? Thanks
Sep 30, 2009 | Garden
I am looking for a manual for a Ryobi 700r
Gday,
Just check out :
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Have fun :-)
Sep 22, 2009 | Garden
Unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Jun 02, 2009 | Ryobi Cultivator
Ryobi Cultivator Logo
611 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
