Question about Cycling
I've a 24 speed. The gears slip when I move into 7th or 8th gear. Also does not seem to want to go up onto top crank.
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the issue
Thanks for using FixYa.
Posted on Jun 06, 2010
What is the maximum speed of fiat croma 1986
their are 12 croma s for 1986 her they are1986 Fiat Croma 1600 Croma 1a serie model for Europe , 5-door hatchback with manual 5-speed and 1585 cm3 / 61 kW (82 hp / 83 PS);1986 Fiat Croma Turbo i.e. Super cat Croma 1a serie model for Europe (since mid-year 1986), 5-door hatchback with manual 5-speed and 1995 cm3 / 110.5 kW (148 hp / 150 PS);1986 Fiat Croma Turbo i.e. Croma 1a serie model for Europe , 5-door hatchback with manual 5-speed and 1995 cm3 / 114 kW (153 hp / 155 PS);1986 Fiat Croma CHT Croma 1a serie model for Europe , 5-door hatchback with manual 5-speed and 1995 cm3 / 66 kW (89 hp / 90 PS);1986 Fiat Croma i.e. cat Croma 1a serie model for Europe (up to mid-year 1986), 5-door hatchback with manual 5-speed and 1995 cm3 / 83 kW (111 hp / 113 PS);1986 Fiat Croma i.e. cat Croma 1a serie model for Europe Switzerland , 5-door hatchback with manual 5-speed and 1995 cm3 / 84.5 kW (113 hp / 115 PS);1986 Fiat Croma i.e. cat Croma 1a serie model for Europe (since mid-year 1986), 5-door hatchback with manual 5-speed and 1995 cm3 / 85 kW (114 hp / 116 PS);1986 Fiat Croma i.e. Croma 1a serie model for Europe , 5-door hatchback with manual 5-speed and 1995 cm3 / 88.5 kW (119 hp / 120 PS);1986 Fiat Croma i.e. automatic Croma 1a serie model for Europe , 5-door hatchback with automatic 3-speed and 1995 cm3 / 88.5 kW (119 hp / 120 PS);1986 Fiat Croma Turbo D Croma 1a serie model for Europe , 5-door hatchback with manual 5-speed and 2445 cm3 / 73.5 kW (99 hp / 100 PS);1986 Fiat Croma D Croma 1a serie model for Europe , 5-door hatchback with manual 5-speed and 2499 cm3 / 55 kW (74 hp / 75 PS);
http://www.automobile-catalog.com/ the max speeds are 1st -132 2nd-154 3rd -131-4th-152 5th-135 6th -135 7th-135 8th-145 9th-126 10th-128 11th -134
Sep 07, 2016 | 1986 Fiat Croma
Gears seem to want to slip out and make a winning noise in certain gears too is my gearbox done for or is it more likely clutch it's Audi a3 with 130000 on the clock and clutch is very high too any...
gears slipping out will be indicated by the gear lever jumping into neutral.This can be from incorrect rear engagement from a loose worn pivot in the gear lever tower or something stopping the gear lever from moving properly.. Clutch problems are indicated by --going to the floor. crashing 1st gear, engines rpm s climbing without an appreciable vehicle speed increase. If there is a fault in the gear box it will be only in the gear engaged (missing teeth-chipped ) and not all gears. If it is a bearing then there will be no noise in 4th gear
Boxes are repairable as mostly it only needs that faulty part to be replaced
Dec 22, 2014 | Audi A3 Cars & Trucks
1997 VW Jetta Gearbox Slips! I downshifted from 5th to 4th as I was merging onto a freeway connection ramp; but had to speed up immediately to ensure I was able to merge to the freeway lanes; so when I...
Symptoms are those of a clutch up for replacement. There's a thin layer of clutch plate left before the rivets holding the plates hit the metal clutch surface. The effects you describe are quite normal.
There are 2 flavors of clutch replacement - new and refurbished. Both usually can be obtained through a WV dealer. The difference is usually warranty and price.
Jul 03, 2011 | Volkswagen Jetta Cars & Trucks
Loosing speed top end dropped by 15-20mph
tyre pressure is big one so easy to check so common not to
also checking your chain is tight enough but can still move 1-2cm this will cause low power at takeoff and gear slipping but if bike not new could need new chain and crank set wont break the bank hope this helps helped me
Oct 19, 2010 | 2003 Suzuki GZ 125 Marauder
I have 7 gears on my mountain bike, but when I shift into 7th gear it doesn't shift at all. How do I fix it so I can get 7th gear to work? Thanks, R. J.
THE REAR DERAILIER HAS 2 SMALL SCREWS. UNSCREW ONE OF THEM MORE.THIS SHOULD ALLOW THE DERAILIER TO MOVE OVER MORE
Sep 08, 2010 | Cycling
I have a JD 2020 1970. The brakes lock up when I
sounds to me like the caliper/piston/cylinder is freezing up on it
try looking at replacement
Oct 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My bike has 21 gears the new wheel only has 18 gears w ill the bike work
yes it will. You will have to adjust the gear shift cable so that it doesn't go past the 6th gear on the wheel (as you would've had a 7th gear) otherwise your chain will constantly slip off the wheel and jam up
Sep 30, 2009 | Cycling
Slipping while cranking
The rachets in the rear gear cog have gone bad.  Buy a new gear cluster and have it installed on your rear wheel.  about $30
Mar 26, 2009 | Mountain Bike Bmx Fit Gt Haro Chrome...
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Cycling Logo
22 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
