Question about Whirlpool LGV4634JQ Gas Dryer
Dryer ran for over a hour. No heat . timer never moved
The dryer ran but with not heat
  • Whirlpool Master
  • 43,501 Answers
Hi, If you have a gas dryerDryer ran for over a hour. No heat . timer never m - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Dryer ran for over a hour. No heat . timer never m - 2_bing.gifour dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bingDryer ran for over a hour. No heat . timer never m - 2_bing.gifs= Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 28, 2010
4 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
  • 530 Answers
SOURCE: New Dryer and there is no heat and the timer is not moving !
you need to first check your power do you have 240 nstraight across your receptical? i would flip breaker on and off. see what happens...what was wrong with your other dryer?
Posted on May 04, 2010
heatman101
  • 43501 Answers
SOURCE: dryer will not heat, plus timer will not move
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 13, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
No Heat, No Airflow
Need to replace the timer.
Dec 09, 2013 | Roper REX3614KW Electric Dryer
Not heating, and timer drying ran for hours
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 26, 2011 | Whirlpool Dryers
The dryer ran fine and heated and cyclked the electric element fine but the cycle did not move at all so it just stayed on for hours even after the clothes were long dry
sounds like you have a timer motor problem to me that can be an costly repair but not a hard thing to fix if your mech inclined you can remove the back panel at the top of the dryer and most timer assembly have quick dissconnects and only will plug in one way and if i rembember right a screw or two will have to be removed get your mod and serial number an call your local appliance parts store they can give you a price of a timer assem
Sep 24, 2010 | Kenmore 67082 Electric Dryer
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
May 04, 2010 | Roper REX4634KQ Electric Dryer
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
I have frigidaire electric dryer - drum turns - no heat - timer switch/dial does not advance
replace timer,,than see if it heats,,if you ran this unit with timer not moving,,you made need to change thermerstats
Dec 26, 2008 | Dryers
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
180 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
