Question about Ricoh Aficio SP C231SF Color All-In-One Laser Printer
On a ricoh c231SF getting an Density Sensor Require Cleaning message. How do I clear/Fix this issue
3 Suggested Answers
  • 9 Answers
SOURCE: Density sensor out of range
The density sensor is located in what is called the Colour Registration Detection Assy. When you open the front door where the ETB belt is, the assembly sits were the door closes at the top on the printer side.
It can get toner on it, so check it and give it a clean. But do not touch it with your fingers.
Posted on Oct 22, 2008
  • 884 Answers
SOURCE: HOW TO CLEAR SC 990 MESSAGE IN RICOH AFICIO 2022 APPEARS WHEN SWITCH ON THE MACHINE?
Hi
I have found this explanation of the error message:-
Description: Software performance error
The software attempted to perform an unexpected operation
Causes: • Software defective • Internal parameter incorrect • Insufficient working memory • When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
This can be confirmed here:
Error Codes Ricoh Aficio 2022 Code 990
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 31, 2014
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
Why do I have error code SC542 on richoh aficio sp6330N
542 is usually a fuser error. Thermistors. You should give your local Ricoh agent a call let a technician come and fix thermistors with new ones.
Jul 02, 2014 | Ricoh Aficio SP C231SF Color All-In-One...
Color not registering
Try going into the diagnostics of the printer.
Either in the menu, or network connection.
Try running a clean process if this has one.
How long had your toner run out for.
Try pulling all toners out, then see if you can pull out the spool drum (printing drum)
check that they are all clear.
Are you using original toners, or remanufactured ?
Also check if you have an excess toner cup.
This may be full and require either emptying or replacing.
Apr 03, 2014 | Ricoh Aficio SP C231SF Color All-In-One...
E=9 Ricoh FW 780 Black and White Copier
toner density sensor voltage is less than 0.5 volts or more than 4.5 volts.
cLEAN THE
1) Toner density sensor 2) Flow of the developer at the toner density sensor area
Jul 02, 2012 | Ricoh FW 780 Black and White Copier
Printing envelopes SP C231SF
How do I print envelopes from my Richo spc231sf
Jan 25, 2012 | Ricoh Aficio SP C231SF Color All-In-One...
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Ricoh GX3000
ERR (990) or ERR (999) are both error messages which are displayed when a sensor does not work normally due to dirtiness. For example, either may be caused by a dirty maintenance unit or clogged ink nozzles. It may be possible to resolve the issue by cleaning the device
look here for instructions:
http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Jan 25, 2008 | Ricoh Aficio GX3000 All-In-One Printer
Sc 372 error
have you calibrated the drum?if not when calibrating the drum potencial sensor at the process control initial setting the rate of the change of drum potential sensor outputwith the voltage on the drum out of specification
Oct 01, 2007 | Ricoh 6513 Copier
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
Ricoh Aficio SP C231SF Color All-In-One Laser Printer Logo
853 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
