Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Brush won't rotate
The brush is not spinning and it is not picking up the dirt What can i do
    President:
  • 1,796 Answers
Hi!!
Check belt, probably broken. it is located on one of the ends of the brush, you may need to remove a couple of screws to gain access to it.
Replacements can be found at Walmart, Home Depot, or an Authorized Kenmore Service Center.
Don't forget to rate this post. Good Luck!!
Posted on May 27, 2010
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
Why won't shark cordless stick vac motorized brush work?
Is the brush rotating, if not the belt is broken or jammed, if so remove the bottom plate and all will be reveiled.
Oct 17, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
Why does the rotating brush not work ?
Check to make sure rotating brush is turned on and check for broken or worn belt
Sep 02, 2014 | Electrolux Vacuums
Why is my vacuum not pick up
Hi! Your vacuum is most likely not picking up because of a clog, dirty filter or worn belt or a combination of the three. Please try these trouble shooting steps below.
1. Check that the brushes are still spinning. If not replace the belt.
2. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the hose.
3. Remove the dirt cup. Remove the red baffle tube by rotating 1/4 turn counter-clockwise. Clear the baffle tube of any hair or debris. Replace the baffle tube.
4. Remove the filter from vacuum base. Hold filter under running water to rinse. Allow 24 hours to air dry before replacing.
Hope this helps get your vacuum back up and running!
Aug 05, 2014 | Dirt Devil Breeze Bagless Cyclonic Upright...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The brush is not spinning so its not picking up any dirt
Most likely your brush needs to be removed and cleaned. Clean all debris that might be in the bristles of the brush. You will see a holder for the brush on each end that holds it into the frame of the vacuum. The two holders should turn freely. If they do not, spray a bit of WD40 between the brush and the holders and rotate the holders around the brush. Doing this will clear up the most common occurring cause of the problem you are facing. One other important item is the belt that drives the brush. Make sure it has not broken or stretched. If it has, replace it while cleaning the brush.
Good luck and feel free to contact me if you find this does not solve your problem.
Paul
Sep 19, 2010 | Hoover Vacuums
I have a hoover elite 200 it did not have a belt on it when i got it and i cant find the drive shaft.
You must remove the lid of the vac and find the pulley end of the brush. directly behind it one hand length you will see a small silver shaft. If the shaft is other than silver it is coated with burned rubber. or rust and dirt.
Clean off the burned rubber polishing the shaft with wet dry sandpaper . Then rotate by hand to test for any blockage in the motor fan. Also rotate the brush roll to see that it spins freely. Using a genuine hoover ELITE belt wrap the belt around the motor shaft and brush roll and use the brush to stretch the belt forward as you lower the brush into place. Once seated , rotate the brush again to see that the belt is turning, then reinstall the lid. Do not pick up anything larger than your fingernail or you will blow the fan on this unit.
Sep 12, 2009 | Vacuums
Irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Jul 02, 2009 | iRobot Roomba 570 Robotic Vacuum
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
256 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
