Question about Palm III
Just a quick question
What do I need to do to make the contrast darker so I can see all of the icons on my Palm III
    President:
  • 1,017 Answers
I think on that model there's a touch icon in the left bottom corner, if you tap there it opens the brightness feature. If not it's in the Preferences.
Posted on Apr 07, 2008
Lost my user's guide need to change make copies darker
May I know the model # of your machine?
Some of brother machine have the copy options where you can change the brightness, contrast and color of the document that you are copying.
For example for MFC-240:
You can change the brightness contrast by pressing copy mode. Then load the document in the feeder, press copy option so that it will show the option to change the brightness, contrast and color. Just press the arrow key to select the brightness then hit ok/menu. then press arrow key to have it lighter/darker..
Hope this helps.
Mar 29, 2011 | Brother Office Equipment & Supplies
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
How can I get my printer to print darker. It is not on toner save and has new toner and new drum and I cleaned the scaner .
Open Menu /properties and the contrast can be set UP to your desired level.
You must access this menu on the printer ICON , click and set.
Nov 01, 2010 | Brother HL 1440 Laser Printer
I WANT TO COPY A DOCUMENT DARKER
There should be a menu item or button that allows you to adjust the copier's brightness or contrast. The icons may be represented as a circle with half-white, half-black center, or as a circle with lines surrounding it, like a sun.
It would help to know your model of copier, or at least your manufacturer.
Jun 21, 2009 | Office Equipment & Supplies
I have a bell south phone model# 8823 which has been discontinued and i don't have the instructions anymore i need to know how to make the screen appear clearer so i can read the numbers. All i remember is...
press the menu button, then press the down arrow until it says "set contrast" then push the menu button again and then push the up arrow for darker contrast, the down button for lighter. when finished, push the menu button again
Dec 01, 2008 | Lands Phones
Bad contrast and overlapping images
Try reloading your firmware, or checking for an update.
http://us.creative.com/support/downloads/download.asp?MainCategory=213&nRegionFK=&nCountryFK=&nLanguageFK=&sOSName=Windows+XP&region=1&Product_Name=ZEN+Sleek&Product_ID=13599&modelnumber=&driverlang=1033&OS=10&drivertype=4&x=24&y=12
Jan 10, 2008 | Creative Labs ZEN SLEEK MP3 Player
Quick install not working
If you look on your palm, do you know what the Palm name is?
You can find this by clicking the hotsync icon once and it should appear in the upper right hand corner.
Then in quick install, make sure the name in the drop down window matches. You could be installing the files to the wrong profile.
The other thing to check is to make sure your palm is successfully syncing. The hotsync icon on the palm should show the last successful sync time and date.
Jan 05, 2008 | Palm Tungsten T5 Handheld
Images go suddenly darker
Turn off the the OPC feature in the Menu. If that doesnt help, what youre seeing is most likely the Advanced Dynamic Contrast going to work. In layman's terms, it automatically adjusts the contrast depending on the video signal it is receiving. If you want to disable this, change the AV settings to "User" (button underneath the bottom door on the sharp remote)
Jan 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Palm III sync program for outlook 2003
You can get a compatible palm desktop software and install it. it will let you sync again. you can get the palm desktop software from link below http://kb.palm.com/wps/portal/kb/common/article/33529_en.html
Sep 13, 2005 | Palm III
Sync Outlook 2000 with 2 user accounts, 2 PDA, in XP
One Word
DONT!!!!!!!!!!!!!!!!!!!!
Palm can't think that fast.......especially with 3rd party!!!
Sep 11, 2005 | Palm III
Palm III Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
