Question about Nakamichi AV-8 5.1 Channels Receiver
I'm trying to program my Dish Network remote to my Nakamichi AV-8 and can't seem to make it work. I know I'm doing it correctly because I've tested it with another receiver. Any ideas on which code I should use? There is only one for Nakamichi in the Dish Network book. Thanks
    Novelist:
  • 123 Answers
We would be happy to help with that. Here is a list of someof the codes that we have for your Nakamichi Receiver: 671, 748, 750, and 649.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Nakamichi Receiver provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Nakamichi Receiver. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Mar 14, 2011
Thomas Faust,
Ron,
I am not sure which codes were used, but you can check out http://www.mydish.com/support/apps/remotecodes.aspx to view our entire list available. I am unsure if the AUX mode will work with the OTA converter. I have listed the steps below to do a power scan which lets it go through all available codes. If you have a model 20/21.0 remote, you can also utilize the learning function on the remote.
With the OTA Converter on, press and hold the AUX mode button (about six seconds) on the top of the remote until all mode buttons light up, then release. Press 2, then press STAR (*)
Press the Up arrow button once per second while pointing the remote at the converter. If the code for it comes up, the equipment power off.
When it does, press the POUND (#) button. If the code entered is valid for the remote, the mode light will flash three times. To verify the code works try several different functions for that equipment.
Tommy Faust
DISH Social Media Representative
Apr 19, 2013 | DISH Network ViP 211K
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Remote controller for Nakamichi AV 10 amp. stopped working last night despite replacing new batteries. Red LED not illuminating when 'power' button depressed. Any suggestions for repair/replacent of...
I got the Nakamichi Av-10 i too face the same problem i just tap the remote with my palm and it starts working...:) just try this am sure it should work
Jan 07, 2011 | Nakamichi AV-10 Receiver
Programar tv jvc con control remoto dish network
fidgar,
If I understand you correctly, you are having a problem with you DISH Network remote operating your JVC TV? What type remote do you have? If you look on the back at the top, you will see an 2 digit number; e.g. 3.0 ir. Please let me know what the model number is and I can provide you with code to try to program the remote to your TV.
Ray Calo
DISH Network
Jan 03, 2011 | DISH Network IR Remote Control
Remote code for dish network
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment. Let me know if this helps and please rate the solution.   lone99star
Jan 10, 2009 | Televison & Video
How to program my DISH Network remote to my DVD player?
It's kind of silly but I just pushed the VCR mode button, pressed the power on and off mode button & pressed the up button until the remote found the code. Took awhile but it finally worked.
Dec 28, 2008 | DISH Network DVR-625 DTV Receiver /...
Av mode no remote
Just off the top of my head I think the code was 720... I havent installed DishNetwork dishes in a while though.. I will double check to get you the right code.
Mar 15, 2008 | Durabrand BH1304D 13" TV
Programing dish network remote control for aiwa av-x220
You will have to call Dish Network.
800-825-2557
Feb 22, 2008 | Aiwa AV-X220
Tv is in AV mode
you would need to purchace a universal control you can find these in shop like currys ask the teqs there or look on ebay for a remote like your old one
Dec 28, 2007 | Durabrand BH1304D 13" TV
Dish network
With the dish remote and do a code search as described in the remote manual and see if you can find it that way. If you go through the entire code search and none of them turn off the VCR/DVD combo, then there is nothing you can do, as those codes in the remote are all stored in the remote and they cannot be programed in. If you do not have a remote manual to set up the remote, to do a code search, simply go to the dishnetwork web site and search for it.
Sep 27, 2006 | Emerson EWD2004
Nakamichi AV-8 5.1 Channels Receiver Logo
367 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
