Question about HP LaserJet P4014n Printer
Laserjet P4014. Are there problems that arise when the maintenance counter is reset, like there was on the P4515?
When i connect by USB cable the error message comes this windows not recognized the device the windows is windows xp professional
Posted on Aug 04, 2010
HP LaserJet P4515 Streaking
It is possible that the cleaning blade on your toner cartridge is malfunctioning. Try replacing it.If you can time it right,try shutting down printer in middle of print job when copy is between toner and fuser and see if the problem is before it reaches the fuser.
Apr 22, 2014 | Office Equipment & Supplies
Cold reset hp p4515
Power off the printer, power the printer on and when the memory count starts in the display, press and hold the checkmark button until all three lights on front stay on. Release the checkmark and use the up arrow until display reads "cold reset" and then press checkmark again and printer will restart.
Apr 15, 2014 | HP P4515n LaserJet Printer
How to staple a laserjet p4014
You need to have the LaserJet 500-sheet stapler/stacker accessory installed.
You would then need to select the stapler/stacker as the output device in your print driver. See the printer driver online Help for details.
Apr 07, 2014 | HP LaserJet P4014n Printer
I've tried to reset the maintenance-kit counter with this procedure but had no success 1 Turn the MFP off and then on. 2 When the memory count appears on the control-panel display, press and hold 6...
You can try to go in the service menu.
You can find this in the administration menu, go all the way down and you will see "service".
You need to insert the service code : 11434506
From there you can reset the maintenance count i guess.
Apr 21, 2017 | HP LaserJet 4345mfp Printer
Maintenance reset
Reset the maintenance-kit counter
1. Turn the product power off and then on.
2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds.
3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT.
4. Press OK to reset the maintenance-kit counter.
May 22, 2013 | HP Laserjet P4515x Printer
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from hp.com, version 4.060.7 or higher. The firmware can be downloaded from hp at "hp.com/go/support" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
EFFECTIVE DATES
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
Can't reset maintenance count on laserjet p4015
Reset the maintenance-kit counter 1. Turn the product power off and then on. 2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds. 3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT. 4. Press OK to reset the maintenance-kit counter.
Aug 03, 2010 | HP LaserJet P4015 Printer
HP 4345. Need to reset the Maintenance kit error. How do I get into ther Service Mode and how do I reset it? Thanks!
To reset the maintenance-kit counter
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Jun 08, 2009 | HP LaserJet 4345mfp Printer
HP LaserJet P4014n Printer Logo
340 people viewed this question
Seeker5211
Seeker5211
