Question about Dishwashers
Hello I have a hotpoint aquarious dishwasher and its making a burning smell and tripping the fuse box do you know what this could be?
  • Michael Thomas
    Michael Thomas May 27, 2010
    Hello there: Please read Often the main wiring connection from the house,
    at the dishwasher, burns and breaks the connection. If that's the
    problem, the wires must be repaired/replaced as necessary. If that's not
    the problem, check the wiring to the door switch, the wiring between
    the door and the lower part of the dishwasher, and the wiring to the
    timer. Repair any broken, burned, brittle, or defective wiring, using
    the proper appliance-grade wire and connectors.
  • 909 Answers
Almost certainly the main wash motor or the capacitor is faulty.If not look for the line filter module. If that is blown it will also do that.Rewire without it.(your mail power cord is connected to it as it enters the machine on the inside..
Posted on May 27, 2010
My Hotpoint ultima super silent dishwasher blocked in the night and tripped the fuseboard. I have cleared the blockage but whenever I turn the mains back on it keeps tripping the fuse before it can resume...
also check for a burned heating element, once you locate the element in the lower dish washer look i over for damage , you could also remove the wires from the lower element and then try ad see if it works ifthe unit works
replace the element
you have a short somewhere just trying to eleminate some items
Oct 31, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Our dishwasher made a loud pop the other night, and there was a smell of burning plastic/rubber. Since then it has stopped working. No fuse was blown or tripped it seems to be local to the machine. I...
You would probably need a whole new motor but the nwith the smell of plastic you may also have a burn hole in the tub. Your best bet is to replace the whole thing. Sorry
Aug 03, 2010 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Hotpoint Aquarius SDW60 is tripping the mains power
is the circuit protected by an rcd/rcbo or a standard mcb as this may be a neutral to earth fault/insulation breaking down...try and get the machine portable appliance tested
Sep 05, 2009 | Hotpoint 24 in. FDW60 Free-standing...
No power
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
Aug 28, 2009 | Hotpoint Dishwashers
Dishwasher trips the fusebox.
You have a obvious short circuit.
Remove the lower panel and inspect the drain valve solenoid attached to the pump beside the motor.
These GE solenoids will stick and melt causing a short circuit.
If not that, open the front panel and inspect all wires for a break.
May 26, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Apr 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
Jan 29, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Jan 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
157 people viewed this question
Top Dishwashers Experts
