Question about Ricoh Caplio R7 Digital Camera
Digital camera lens stuck
Ricoh digital camera. Lens is stuck in protracted position, camera does not operate
  • cami_sahaja May 27, 2010
    Thanks for the speedy reply. I'll give it ago. I had heard that it does cost more to repair than to buy anew.
  • 10,515 Answers
I am Sorry to hear regarding the Problem.This is a ' Lens Problem ' which is Quite Common on these Models.
It is not worth to get it Repaired, as the Cost of repair would be quite high as compared to the cost of the new camera.
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
5. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
6. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
If no luck then only other option is a serviceman I'm afraid, be sure to get a quotes as camera repairs can be uneconomical
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 27, 2010
Lens stuck and I cant get the camera turned on. I have a nikon coolpix s4100
Low battery voltage left the lens in a position that the electronic circuit can not resume the next operation. Its a typical Nikon digital camera problem. The tolerance on the lens barrel maybe too tight. The solution maybe replace the lens assembly.
Feb 10, 2012 | Nikon Coolpix 4100 Digital Camera
Lens error. lens is currently retracted. will not open. nikon s8100 bought xmas 2010.
Had issue with lens stuck and not retracting on nikon s8100. first removed battery. then manually (gently) rotated lens counterclockwise until lens seated in fully retracted position. inserted battery, turned camera on and camera operational again. I suspect that root cause of lens jamming was turning off camera while simultaneously moving zoom lever
Mar 11, 2011 | Nikon S8100 Digital Camera
I need to convert my manual lens to a digital body. what digital
If you have Ricoh lenses that do not have electrical contacts, you can use the lenses on Pentax digital SLR cameras.
If you have Ricoh lenses with electrical contacts, you can not use them on Pentax digital cameras.
Jul 10, 2010 | Ricoh XR-10M 35mm SLR Camera
Kodak EasyShare M863 Digital Camera -Blank screen
Hi Greg, Its not on the settings., Here the thing you need to Do
Turn Off the camera, remove the memory card then Turn On the camera and go to auto mode or smart scene., now if yu see black screen check the Lens is yur lens has cover or check if the Lens protracted. Now if the Lens has no cover and protracted thats good it means theres no problem on the lens., Now press Menu Button, If the options did not display it means LCD or screen is already defective. you can also press review button.,
Please call kodak Toll Free 1 800 235 6325 and have your camera repair., GudlucK!
Nov 05, 2009 | Cameras
Ricoh R7 Lens Jammed
you would love to see what was the truth as link following,
http://xiaolaba.wordpress.com/2009/04/25/camera-ricoh-caplio-r7-a-real-****-lens-error-00-00-00-30-02-23/
it was a **** design by RICOH, sent your message of compliant to them. you may get free service.
Jan 25, 2009 | Ricoh Caplio R7 Digital Camera
Lens stuck in out position
Replace the camera lens. Or take the camera apart, rebuild and clean the lens, then reinstall the camera lens into your camera. Rebuilding is not as fun as it sounds.
Nov 12, 2008 | HP Photosmart M527 Digital Camera
Having problems with my canon ixus860. When I turn the camera on, the lens can not protract in or out. It's says lens error on screen. Is this a common problem? I don't believe I have dropped this camera...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 12, 2008 | Cameras
Canon powershot SD600
Looks like the lens is "out of alignment". Canon charges heftily for this repair. However if the lens is not broken then many people have got it working through systematic bashing. Click here to view the thread
Jul 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Ricoh Caplio R7 Digital Camera Logo
123 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Greg Cann
Greg Cann
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
