Question about Canon PIXMA MP160 All-In-One InkJet Printer
Are compatible injet cartridges safe to use. If yes can you recommend a supplier.
  • earlandmerle May 27, 2010
    searched Google
    I came away from searching several site that "brand name ink"
    is over priced.
    Compatibles and remanufactured cartridges are fine to use.
    A great sie for finding ink is printink.com.
    They rate companies and have discount coupons
  • 53 Answers
YOu better search google
Posted on May 27, 2010
Having problems with my ink cartridges, now I've used compatible cartridges as advised.
You may have gotten a cartridge that was in the store for a long time. Some cartridges may get solidified ink in the nozzles. Try a new cartridge from another dealer.
Oct 04, 2014 | Epson Artisan 710 AllInOne InkJet Printer
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Apr 22, 2013 | Xerox Phaser 7750DN Laser Printer
My canon injeti560 printer prints color but not black,and the black ink is full,what to do
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 29, 2010 | HP High Quality Compatible Injet...
Alignmn failed. Not reading the black cartridge... After having placing 3 seperate cartridges into the printer i have established that it appears that the 2 compatible cartridges are defctive as once i put...
No, I would not recommend aftermarket cartridges for hp printers.
They might seem like money savers, but it's a hit or miss situation for finding an aftermarket supplier that has the same quality standards as hp brand ink jet cartridges.
I would return the defective cartridges to the remanufacturer.
Jul 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
When inserting cartridges does black go on the left to the canon pizma mp 180 all in one injet printer
Yes Black is usually on the left side... The cartridge and printer should have symbols on which side the cartridge goes on.
Jul 03, 2010 | Canon PIXMA MP180 All-In-One InkJet...
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
May 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Compatible ink cartridges dx8400
Epson cartridges are microchipped.
Do your new cartridges carry the same chip?
If not, they will not work.
If all else fails, return them to the supplier and explain they are not recognised by your printer.
Feb 18, 2009 | Epson CX8400 All-In-One InkJet Printer
Chain
Yes All motorcycle chains currently being manufactured use Buna-N (Nitrile) rubber for their o-rings and x-rings and all these manufacturers recommend kerosene as a cleaner. Here's the formulation of WD-40: 80% Stoddard Solvent (that is similar to kerosene) 20% light lubricating oil and a bit of fragrance. Here's the compatibility of Stoddard Solvent with rubbers and plastics: Good Compatibility (OK for both static and dynamic seals) Buna-N (Nitrile) Chemraz Epichlorohydrin Fluorocarbon Fluorosilicone Kalrez Nitrile, hydrogenated Polyacrylate Teflon, virgin Mixed Compatibility (OK for static seals, but not for dynamic seals) Neoprene Vamac Fair Compatibility (OK for some static seals) Polysulfide Polyurethane, millable Poor Compatibility Butyl Ethylene-Propylene Hypalon Natural rubber Silicone Styrene Butadiene Consequently, WD-40 is safe and effective as a chain cleaner and corrosion inhibitor. Link: http://www.efunda.com/designstandard...dard%20Solvent If you clean with a soft brush and WD-40, and plan to follow-up with a chain lube, you can reduce chain lube sling-off if you first remove the oil residue that WD-40 leaves. This residue seems to prevent some chain lube formulations from sticking well to the chain.,,,
Nov 10, 2008 | 2004 Skyteam ST 125 TR
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
110 people viewed this question
old marine
old marine
