Question about Onkyo TX-SR606 Receiver
The sound go cuts in and out then out
I get a message that says "Protect".......Box seems very hot......I just changed speakers ....I did attach antenna wire the same as it was to the old speakers...... When I turn off for awhile the sound does come back for awhile....then goes off again
  • 1,170 Answers
You have to replace the power output assembly.
Posted on May 27, 2010
  • 2 more comments
  • carol_scholl May 27, 2010
    I am not sure what you mean?
  • Arjun Komath May 27, 2010
    From what you said, it indicates a possible short in the circuitry. Probably a capacitor that is intermittant or even a transistor about ready to fail. This is probably not something you can look for if you are not an electronic tech. Find a reputable shop and get it fixed before it quits and does more damage.
    I had just replaced larger floor speakers with klipsch s3 speakers....smaller table model ones...It did not do this before this.....could the speakers be switched left and right position...or could the wire be wrong....I thought I connected the same way to the back of each speaker as before ....? I did not replace existing wire....
    The problem is with the receiver and not with the speakers.
Unit cuts off. I turn it back on and it turns itself back off. Confused...Please help
Sounds like a speaker wire is shorting out, check there are no breaks and/or positive and negative terminals on the amp and speakers are the right way around
Aug 07, 2013 | Yamaha RX-V2600 Receiver
Protect mode
The most common cause of this is that one of the speaker voice coils is shorted or the wiring to one of the speakers is shorted. Disconnect the speakers one at a time and see if the amp goes out of protect, if no change you have a shorted output circuit in the main amp section.
Dec 23, 2011 | Teac AG-D9260 Receiver
I couldn't able to switch on my sony str db930 .when it was use it say me protecter.
Check all of your speaker connections... usually the PROTECT cuts in when speaker wires get crossed or you have blown a speaker.
this PROTECT message also shows if the amp chip(s) have blown in the unit
Sep 01, 2010 | Sony STR-DB930 Receiver
I get a message Protect. All other controls are
Usually the protect is a safe mode to indicate that your set is unsafe. Starrt by checking the speakers, speaker wires for shorting. detach the speaker lines and power on the set for confrimation. check in power/auxially circuits in the set. it is possible that your mechanism drive / audio output drive Ic's could have shorted. Most of these cirrcuits have an error detection of higher current to cut off power and issue a protect warning. so discoonect the IC power to confirm. Hope this helps. Good day
Jul 12, 2010 | Kenwood KDC-MP435U CD Player
PROTECT MESSAGE
It senses an error or problem and shuts down. Try disconnecting all the cables and wires attached to it. Try it again. If it still shows protect message, it is an internal fault and requires a repair shop. If it clears up, then the problem may be a shorted speaker wire. Correct the short when reconnecting the speakers.
Mar 08, 2010 | Sony STR-DE545 Receiver
New System Just out of the Box and the very first time I turn it on it checks for all the DVD's and then "Protector Puch power" Message. I check all the wires and Not sure how to do test tone as every time...
Straight to power protect mode indicates crossed wires somewhere or otherwise miswired system. Disconnect all the speakers and try to power on to see if it still goes into protect mode.
If it does, read the manual for troubleshooting tips, or return the unit as defective.
If it does not then replace the speakers one by one until it returns. Check the wires going into that speaker, that speaker may be defective or you may be wiring it wrong.
Aug 14, 2009 | Sony DAV-HDX500 System
My amp is on but no sound
Did you disconnect the battery? You may have bowwn a fuse, but that prolly wouldnt give you a protect light. Protect light usually means a short circuit, probably on the speaker end, sure there couldnt be maybe a single strand of wire crossing over the positive and negative speaker or amp terminals.
Feb 29, 2008 | Crunch P125.4 Car Audio Amplifier
Sound problem
I found out that it was simply my speaker connection. That is, it seemed like a good contact, but in fact the stero was reading "pulsing" from the speakers and shutting off to protect itself. I simply cleaned off the wires and carefully reconnected them.
Jan 22, 2008 | JVC MX-DVA9 System
Protect
I know I'm finding lots of old posts about this JVC model MX-KB30 "PROTECT" problem but - I FIXED IT!!!! 8-) Daugter had the same difficulty after a series of power outages. Figured it had something to do with the speaker circuit board. Decided to look for a reset on the board itself. Not sure that I found one, basically becuase there was not a perception of a button pressing down, but the "PROTECT" cleared and the sound is coming through the speakers again. The sterio works fine. First - as when working on all electronics - unplug the unit and make sure all static electricity has been discharged before working on it. You will need a small jewlers philips screw driver as well as a mirror for looking down on top of the electrical components. Remove the cover of the sterio surrounding the sides and top of the unit - there are screws on the sides, top and around the edges of the back fo the unit related to this piece. You do not have to remove any other pieces. There will be a circuit board attached to the back center of the unit that has a black cable running to the headphone plug and the speaker connections are also running through this board. If you face the front of the unit, looking at the sound circuit board from the right side, there will be a small black - square looking - voltage regulator (I think that's what it is anyway) that you will see some voltage information and some switch setting pictographs (along with the numbers 1, 2, 3). On top of this black unit (here is where you need the mirror) there is a square hole that looks down inside this unit as well as a round hole that you will see white plastic inside. Using the jewlers screwdriver, carefully press on the white plastic once or twice (I couldn't tell that it had pushed down) particularly becuase I have no clue how sturdy this piece is. With the cover still off the unit, plug it in and make sure the "PROTECT" message has disappeared and the speakers are working again. That's exactly what I did and the darn thing started working again. Maybe I just got lucky, but this is a nice sounding unit and it would be a shame to see folks toss it away for such a simple fix if that is indeed what did it. Enjoy!
Apr 13, 2007 | JVC MX-KB30 CD Shelf System
Vollume trouble
the system protect is usually displayed when a condition of short or shorting is occurring in the speaker wiring or the voice coil of any of your speakers.... thte circuit of you reciever is trying to protect itself and you from a very costly repair,,,so it you have another set of speakers try to use them and see if the condition still exists and if it does the problem is in the output section of the receiver,,,and if the protect no longer exists you have fixed your problem,,,good luck
Apr 07, 2007 | Onkyo TX-8211 Receiver
Onkyo TX-SR606 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
