dear sir, thank you...take care
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
if still the problem is the same ,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest olympus service centre and it is going to be done free of cost,as your camera is under warranty .......
thank you.....take care................
thanks, my dad has ordered both for me so fingers crossed i will have it working in time for my hols :)
