Question about Samsung Prostar 816 Phone
How can I turn off the ringer on a secondary phone?
  • 532 Answers
Go to phone menu.
go to profile.
select a profile and personalize it.
select silence and activate the profile.
Posted on Jun 04, 2010
How do you turn the ringer on/off on aatt 993 2 line phone
If you mean the AT&T 993 two-line speakerphone, you can adjust the ringer volume for each line when the phone is not in use. To increase the ringer volume on the primary line (if set), press the Volume Up arrow. To decrease the ringer volume, press the down arrow. There are 8 different volume levels available for the ringer. The Volume Up/Down buttons are below the * and 0 keys.
To adjust the ringer volume on the secondary line, press that line button (between the Conference and Hold buttons) and then press the Volume Up or Down buttons as needed. (If you haven't programmed a primary line, press a Line button and adjust that line's ring volume before pressing the other Line button. Then adjust the volume for that Line.)
I hope this helps. These directions are shown on page 32 of the manual. AT&T currently has the manual here : https://att.vtp-media.com/ecp/documents/product_Product/227/UserManual/5596/993_manual_i14.pdf . To find this manual or other AT&T phone manuals, start here: https://telephones.att.com/product-support/manuals .
Mar 27, 2018 | Lands Phones
Phone ringer off
It a little bit older cordless phone, I CAN'T find the model number, there's a menu/elect button on the face but I can't turn the ringer off. The base has a ringer that I turned off but the phone still rings. There are no switches on the phone or base for turning it off.
Nov 14, 2013 | Northwestern Bell 36028-2 2.4 GHz Twin...
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
Sep 22, 2011 | Panasonic KX-TG5632 Phone
CAN THIS PHONE RINGER BE CUT OFF
To cutoff ringer volume in Vtech cordless phones,you have to turn off the base ringer.
Handset:
program button->up/down" key to cycle until you see the Ringer selection->up/down" key(s) to cycle until the OFF selection
Base Ringer:
Menu->press menu until you hear "Base Ringer, to change base ringer press change"->PLAY/STOP button to save
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Vtech IA5854 5.8 GHz Cordless Phone
Secondary phones will not ring
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset2.gif down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring2.gif assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished. hope that helps
Sep 22, 2009 | Samsung Prostar 816 Phone
How do I turn on/off ringer at secondary handsets?
Dear sdobe,
In menu, type # 160. Then choose 0 or the lower key to turn of the ringer.
The Writer
May 29, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
May 10, 2008 | Uniden Cordless Phone
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Lands Phones Logo
57 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
