Question about Onkyo TX-SR606 Receiver
My voice cuts out
The voice cuts in and out then completely out....I get a "Protect" message on receiver
  • 2,069 Answers
The problem is an amp protection circuit which was designed to keep the 606 safe from a power surge.
Posted on Jun 04, 2010
Our voice messages from outside cut off before message is complete. How do we fix this?
How long are they speaking before it cuts them off?
is it 180 seconds? That is the default for IP office, but you did not state which system this phone is plugged into...
Feb 28, 2013 | Avaya 1408 Digital Phone 700469851
Protect mode
The most common cause of this is that one of the speaker voice coils is shorted or the wiring to one of the speakers is shorted. Disconnect the speakers one at a time and see if the amp goes out of protect, if no change you have a shorted output circuit in the main amp section.
Dec 23, 2011 | Teac AG-D9260 Receiver
Voice and camera not work in yahoo masenger
There are different reason why voice and camera wont work
By the way in what situation its not working
a. The computer cant read the voice headset camera webcam Device b. The voice and camera while on chat wont receive any voice or video during a conversation
a. Solution For the Headset please make sure that you have the audio driver for your computer if not download the latest audio driver for windows depends on your computer operating system
For Webcam Step One Reinstall your Webcam Driver GO TO START then CONTROL PANEL then ADD REMOVE PROGRAM then CHOOSE THE SOFTWARE OF YOUR WEBCAM AND CLICK REMOVE Step Two Once Completely Uninstall Restart your Computer these is the best way to completely remove the remaining floating files left by the uninstall
Step Three Once Completely Restart Install your Webcam Driver then Were Done
Step 4 Now open your Yahoo Messenger and now it works Fine
b Solution
These symptoms exist if you internet connection is slow Kindly Check you internet connection by conducting a speed test or contact you internet provider
Hope It Helps If you want to Know more on how to solve computer Problems you can message me
Mar 18, 2011 | Yahoo Messenger
I couldn't able to switch on my sony str db930 .when it was use it say me protecter.
Check all of your speaker connections... usually the PROTECT cuts in when speaker wires get crossed or you have blown a speaker.
this PROTECT message also shows if the amp chip(s) have blown in the unit
Sep 01, 2010 | Sony STR-DB930 Receiver
I get a message Protect. All other controls are
Usually the protect is a safe mode to indicate that your set is unsafe. Starrt by checking the speakers, speaker wires for shorting. detach the speaker lines and power on the set for confrimation. check in power/auxially circuits in the set. it is possible that your mechanism drive / audio output drive Ic's could have shorted. Most of these cirrcuits have an error detection of higher current to cut off power and issue a protect warning. so discoonect the IC power to confirm. Hope this helps. Good day
Jul 12, 2010 | Kenwood KDC-MP435U CD Player
Can't erase messages shows there gone but as soon as I try recording get message full RCA RP 5050A
Does this unit connect to remote device (computer or ext. controller)? If so, it may be remotely manageable, and if on a Windows computer might get set to "write protect" (which will mean no erase, but doesn't explain why the dir is erased). Some units have a lock or data protect function or button, once again doesn't explain why the list of messages would be gone. Worst case is something's wrong with the firmware, meaning probably not worth fixing.
Oct 23, 2009 | RCA RP5012 Digital Voice Recorder
Stereo cutting off when volume is over 29
Twenty nine sounds pretty loud to me. A shorted voice coil in any one of your speakers will drop its resistance value so if the amplifier thinks its feeding a short circuit, will "protect" itself by shutting off. Check wiring carefully and each speaker at a little lower volume for sounds of distortion ie: shorted voice coils...
Jun 27, 2009 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Getting a "Protect" message in the display which then shuts down
The speaker wires were al little frayed, so I cut and stripped new 3/8" leads and when re-inserted the receiver worked fine. The problem was a short from the frayed wires touching either the back of the receiver or some other metal near the terminal.
Dec 06, 2008 | Sony STR-DE185 Receiver
Vollume trouble
the system protect is usually displayed when a condition of short or shorting is occurring in the speaker wiring or the voice coil of any of your speakers.... thte circuit of you reciever is trying to protect itself and you from a very costly repair,,,so it you have another set of speakers try to use them and see if the condition still exists and if it does the problem is in the output section of the receiver,,,and if the protect no longer exists you have fixed your problem,,,good luck
Apr 07, 2007 | Onkyo TX-8211 Receiver
Onkyo TX-SR606 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
