I have a fault code 41 cannot find hardware device, i see fixes listed by going into the registry but im not confident of changing anything there, is there a free download to fix this?
Here is the explanation and solution for the error code 41:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Good luck.
Posted on Apr 08, 2008
When you say Norton I assume you men Norton Utilities? It is a good program which I have faith in and have used for many years. If it says you need to download the installer I would do this.
It is possible that you need the installer to load the drivers for the DVD drive (though these are usually simple ATAPI devices and generally (not always) the Window drivers will suit the device. Note: I have an LG DVD in my computer which neeeded to install LG drivers from a disk to get it to run.
I presume by "gear software" that you mean the DVD's manufacturer's software?. If not, then like yourself. I do not know why you should need to download the Installer.
Do a Restore Point before installing the Installer just in case something is wrong here.
After you have installed the Installer and run the driver install again, let me know if it works.
Good luck.
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Feb 10, 2012 | Pioneer Computers & Internet
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 25, 2010 | Philips (JR4DVDRWK/00) DVD+RW Burner
Feb 07, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
Jan 01, 2010 | Acer Computers & Internet
Oct 16, 2009 | Lenovo IdeaPad Y530-5243U
Oct 04, 2009 | Philips DVDRW 228K DVD+RW Burner
Nov 05, 2008 | NEC Computers & Internet
Nov 10, 2007 | Toshiba Satellite A100-S8111TD Notebook
Nov 05, 2007 | Teac (DW-224E) DVD Drive
Apr 24, 2018 | Computers & Internet
298 people viewed this question
thanx for your reply, have already done these but still did not work,I found a link on another site
http://aumha.org/win5/a/xpcd.php#problem...
this seems to have worked, but not sure whether this has changed anything else. I did a full scan after downloading this fix and norton then told me I needed to download a driver installer from gear software, why would I need this?
everything working fine now, amazed that someone out there actually took time out to answer my problem, this site is great will tell my mates about it. thanks
