Question about SaniServ 407 10 Quart Ice Cream Maker
THE MOTOR NO STARD , MODEL A5011ET - SaniServ 407 10 Quart Ice Cream Maker
Beater overload
if your mix level is low ice cream will freeze in cylinder which in turn will over amp the beater and cause it to trip. Check mix pump and make sure all orings are good.If mix isnt leaking out make sure it is pumping in.
Mar 24, 2012 | Taylor 632-33 Ice Cream Maker
Put a new motor in the left side, but when you try to run it, it keeps tripping the reset button and turning off. The left side controls the hopper cooler, so I come in and the hopper is warm on both...
Did you check the wiring ? This motor is reversible and you may not have the wires under the connection plate. A model number would be very helpful as I am looking at model # 339 manual.http://www.taylorfreezersales.com/op_man/0336_338_339op0.pdf
Jun 29, 2011 | Taylor Ice Cream Makers
My wife dropped our icecream motor and i am wondering where I can purchase a new one
You can try contacting Rival to see if they sell a replacement motor. Nothing is listed on their parts and accessories page. It may just be more economical to buy a new ice cream maker, though. Most of the cost is likely to be in the motor, and even if the motor's available it may be just a few dollars more for a whole new appliance. Amazon.com lists two almost identical models by a company called Maxi-Matic, a 6-quart model for $69.99 and a 4-quart for about $10 less. You might be better off just buying new and get a warranty with it.
Sadly, almost every small appliance now is a throw-away item.
Jun 20, 2011 | Rival 8550-X 5 Quart Ice Cream Maker
New motor makes loud noise when operating
Use a food grade grease to lubricate the gears. The newer White Mountain freezers have Chinese made motor drives and are a piece of junk. Don't confuse the newer models with your old American built machines. If it's still under warranty contact the manufacturer for warranty repair. Read the most recent customer reviews for the 4 & 6 quart electric freezers on Amazon and other websites. You will see a rash of motor failures!
Jul 20, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
Need motor drive and dasher replacements
I cannot find any parts for this. I have one that works great, but my ice cream can is all rusted out. The number is 1 800 557-4825 m-f 8a to 5p est, parent company is Jarden Consumer Solutions. Can't find anything for parts on thier website either. However, you can buy a whole new one for 62.50! It just doesn't make sense!
Nov 18, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
My motor assembly has a stripped gear. I tried ordering a new motor assembly but can't get one. I took the assembly apart and found that there are 2 gears that look the same. One is damaged. I could...
you seem to very short on required data , like make , model year , type of equipment
until you post again with all of that detail plus the statement , it is unlikely that anyone can help you
Nov 03, 2017 | DeLonghi ICK8500 IceCreamery 1.5 Quart Ice...
SaniServ 407 10 Quart Ice Cream Maker Logo
82 people viewed this question
Top SaniServ Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a SaniServ Ice Cream Maker Expert? Answer questions, earn points and help others
