Question about Sony Playstation 3 (PS3) Console
It flashes red 5 times beeps then turns its self off
    President:
  • 1,469 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There's a switch in the back, the only benefit of using the power button is that it can be turned back on with the controller. Dont use the switch when your game is saving or anything is downloading because you could corrupt the saved game/download (I don't think it'll let you turn it off from the front button when it's writing to the hard drive- the switch in the back actually cuts off the power.)
Posted on May 27, 2010
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
Air bag light always blinking?
Mine came on when my car hit 120K mi. I also reset it using a sequence within the car.
Problem Scenerio: turn car motor on, car conducts self test, during which time airbag light stays on for 5-second (or 5 or 6-beeps)..it turns off for a second then flashes 'off and on'...and annoys the hell out of you as you drive...especially at night.
Solution 1: put black electrical tape (band-aid) over airbag light indicator...annoying problem gone.
However, in VA the airbag light can't be flashing to pass the annual car inspection, so....
Solution 2: Reset the Airbag light using the following sequence I discovered and heard about:
1. Turn key / ignition to 'ON' (Do Not Start). and await for the self-testing procedure to end (Air Bag Light stays on for about 5-seconds or '6-beeps')
2. As soon as the Airbag light turns off - turn the ignition to OFF position and count 5-Mississippi's (that's 5-seconds).
3. Then turn ignition back to 'ON' Position and repeat step 1 & 2 again.
Conduct Steps 1 & 2 - Three times in a row.
After the 3rd or successful timed sequence, allow the car to go through it's complete self testing stage and as soon as its done the airbag light will flash...but at a slower pace (That is good!) That means the cpu is resetting. Once you observe the slow flashing airbag light, turn the car off, then start it normally and the airbag light 'should' reset (not flashing and bugging the **** out of you).
Then, take the black electrical tape off the dash panel and throw it away.
This is no joke and it really works!! if you have any questions, contact me. carl@sat-tel.com
Apr 28, 2010 | 2001 Nissan Maxima
LaFree Sport Problem - Beeps Twice and LED's Flashing
the matter of beeping is not so serious than the flashing of those LED's every second just get the fuse and the circuit board checked its no self work
Sep 09, 2009 | Electric Bicycle Motor, Bike,electric...
Red light flashing 4 times, tv turns its self off
Start by removing and inspecting the bulb. The filament you're looking for is encased in the glass tube in the center of the lamp itself. Kindof difficult to see unless you're at the right angle. 9 times out of 10 that solves the problem. If not move on to the ballast, the small circuit board directly underneath the lamp housing.
Jan 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
