Question about HP LaserJet 4700 Printer
4700 keeps jamming by the fuser. Ran diagnostics on all motors and replaced fuser with one from a working printer.
SOURCE: Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Posted on Jan 10, 2008
leroyal
  • 2120 Answers
SOURCE: HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Posted on Mar 12, 2009
  • 99 Answers
SOURCE: Seems to jam in fuser, fuser has been replaced
if it always jams at the same place (fuser area) try another fuser or check the BLACK PLASTIC ASSY. THAT is mounted in the left door and takes the paper right after it comes out of the fuser ;part is called (PAPER DIVERTER) And sometimes one of the FLAPS That routes the paper is broken,hence causing paper jam.
Posted on Aug 01, 2009
  • 81 Answers
SOURCE: replaced the fuser in an HP 4700, and it is still
It's recommended to replace the low voltage power supply next, then the DC controller board
Posted on Oct 12, 2009
  • 742 Answers
SOURCE: hp lj m4345mfp printer showing 13.31.00 fuser
If you are using Windows:
  1. Click on Start => Settings => Printers and Faxes
  2. Locate your printer's name and right click on it and click "Printing Preferences"
  3. Under the "Main" (General tab in some other printer models) Tab, and under "Paper Options" group, select the settings for "Paper Type" Paper Size"
  4. Click "Apply" and the click OK.
Your values here will be the default values loaded when you click the print command in any programs in your computer.
Posted on Feb 09, 2010
What to do now hp 4700 13.xx.xx jams all different types.
With all you have done already I'm sure you have cleaned or replaced the pickup roller as this is the most likely cause.
This is a difficult printer to work on and parts are hard to come by so I would get an opinion from a local HP expert.
If the printer works okay with single-side jobs, you could just manually duplex your jobs.
Jul 01, 2014 | HP LaserJet 4700 Printer
Fuser Pressure release Motor Diagnostics 13.20.00 error
Check for paper jam at the fuser. Be careful not to damage the delicate fuser film.
If no paper, check the sensor there may be stuck or dislocated. Otherwise get a fuser replacement kit.
Dec 17, 2013 | HP Color LaserJet 3600 series printers
Hello how to reset fuser in hp 4700 whitout
fusers include a tiny "fusable link" that "burns itself out" during the 1st power-on. Basically you must install a replacement fuser then turn on your printer, and the power-on process will automatically reset the page count for you.
Sep 18, 2013 | HP LaserJet 4700 Printer
Printer keep says replace fuser kit
These is a part on the fuser called a fusable link that blows the first power up cycle and resets the replace fuser message. It sounds like the fuser you installed is a remanufactured unit that was not professionally rebuilt. Contact the place of purchase and get a replacement. The message can only be reset with the fusable link on the fuser.
Feb 13, 2012 | HP LaserJet 4700 Printer
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
In your best soulution for fixing the 59.30 error code on a hp 4700 printer it states to remove the duplex devise from the printer. what is the duplex device and where is it located
Duplex is here:
But 59.30 error (Fuser motor startup error/Black or N/A)
Follow next instructions:
Fuser motor error
1. Reconnect the connectors J4605 for the fuser motor and J1024 on the DC controller PCB.
2. Run the component test to verify that the fuser motor is working correctly.
3. Replace the fuser motor.
Aug 01, 2011 | HP LaserJet 4700 Printer
Ours's a hp color laserjet 4700dn ; the message is 59.30 error ; we bought the machine in the year 2007 what do you suggest?
59.30 states it's the:Fuser motor startup error
Based on the service manual here are the steps to follow:
Fuser motor error
controller PCB.
How to preform the component test below
1. Press Menu to enter the MENUS.
2. Press to highlight DIAGNOSTICS.
3. Press to select DIAGNOSTICS.
4. Press to highlight COMPONENT TEST.
5. Press to select COMPONENT TEST.
6. Select the component test Fuser motor. Use this test to rotate the fuser motor and drive gears.
Menus cannot be opened during component tests, so serves the same function as the Stop button.
More information on a Fuser motor failure detection
  • The DC controller determines the fuser motor failure and notifies the formatter of an error status when it encounters the following conditions.
  • Fuser motor start-up abnormality. The interval of the fuser motor speed detection signal does not reach the specified interval after 1.5 seconds of the fuser motor drive start.
  • Fuser motor rotation abnormality. The interval of the fuser motor speed detection signal stays at an irregular interval for two seconds and longer after it reaches the specified interval.
I've attached a screen shot of where the fuser motor is located It is # 8. tballone.png
Feb 25, 2011 | HP LaserJet 4700 Printer
Hp clj 4700n 59.30 error
The error stands for:
59.XY PRINTER ERROR
X is in your case 3 : FUSER MOTOR STARTUP ERROR.
Y is in your case 0 : NO COLOR
The service manual says:
1. Reconnect the connectors for the fuser motor and on the DC controller PCB. Replace any damged parts.
2. Replace the fuser drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Best regards,
mannu_rakesh
Aug 22, 2009 | HP LaserJet 4700 Printer
Hp color laserjet 4700dn error code 59.30
turn off the printer. remove the duplex device from the printer. turn on the printer. enter the diagnostic menu. enter the menu for sensor and motors. select the fuser motor and let it run. if you can hear it its ok (its not such a noicy one ... you have to listen very good) - follow up the next steps:
turn off the printer. turn on the printer. enter the service menu - pin code is: 09470005. set to 0 all counters for mono print, color print and the counter after service. leave the menu.
turn off the printer, reinstall the duplax device. turn on the printer.
result: the error msg is gone. its just HP wants to sell theyr service contracts.
Feb 25, 2009 | HP LaserJet 4700 Printer
HP LaserJet 4700 Printer Logo
127 people viewed this question
Seeker5211
Seeker5211
