Question about Canon BubbleJet i560 InkJet Printer
Getting an error 5100 on my i560 printer - Canon BubbleJet i560 InkJet Printer
    Sergeant:
  • 284 Answers
Error 5100 & flash 2 times, you need o replace code strip or carriage unit or logic board
Posted on May 29, 2010
I560 printer error 5C00?
A 5c00 error relates to the sensor in the purge unit, which is where the carriage (print head) stops on the right hand side of the printer. You may find that the ink has built up in the purge unit and it will need to be washed out in warm water. The sensor in the purge unit will need to be removed before washing the unit. Problem is getting the purge unit out is quite tricky.
Thanks....!!
Nov 25, 2010 | Canon BubbleJet i560 InkJet Printer
SERVICE ERROR 5100 CANON I560 PRINTER HOW DO i FIX THIS?
Hi There
You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 06, 2010 | Canon BubbleJet i560 InkJet Printer
My Canon i560 stopped printing- snall window
That error says the purge assembly is not moving properly, check for paper stuck over on the right where the printhead parks, also if the squeegee is stuck over the cleaning pads you need to push it back to allow the pads to come up properly.
Jan 10, 2010 | Canon BubbleJet i560 InkJet Printer
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Solution 2:
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
I have a Canon i560 printer and it keeps coming up with error 5100. what do I do?
Error 5100 points to a "carriage jam"
The carriage is the assembly that contains the printhead and cartridges.
This error can be difficult to solve because various things can cause it.
, maybe there is some packing or packing tape that is obstructing the carriage.
Verify that the carts and printhead are installed properly.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've never done it before.
If this does not work, unplug, wait 3-4 min, then re-plug in.
goodluck hope it works
Sep 21, 2008 | Canon Office Equipment & Supplies
Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560
may be ink level is too low,check it first,make sure delete the all pending documents
regrads
prasanna
Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
Canon printer i560 error 5100
Hi You can Try
This been here long time
Error Code 5100
Solution 1:
Solution 2:
Oct 29, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
327 people viewed this question
old marine
old marine
