Question about Panasonic CW-C100AU Air Conditioner
The ac is dripping inside the room
The ac -- a small, 10 year old, 6000 btu panasonic -- is dripping inside the room
    Genius:
  • 1,400 Answers
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
Posted on May 27, 2010
040463610
How large a space are you hoping to cool? One room? One LARGE room? One SMALL room? One floor of a two-story house? A whole four-story house?
What's your climate like where you live? Very hot, dry, year-round? Cool most of the year but two weeks of hot during the summer? Just a little too warm in summer? Blazing hot all summer, including nighttime?
How's the insulation in the building you want to cool? Is it a plain steel building with no insulation? Is it a trailer? Is it a frame house with 4" walls and R13 fiberglass insulation? An old frame house with no insulation? An adobe building? A timberframe house with 8" of polyisocyanurate foam insulation?
All these are important to know when you select an air conditioner.
For most of the USA, assuming a frame house with 4" of fiberglass insulation, a 10,000BTU air conditioner will cool one large room or two small rooms pretty well, or a 5,000BTU AC will do one medium-sized room. Different places, and different house designs, and different types & amounts of insulation, will all have a profound effect on how much AC you need/want.
Jul 25, 2014 | Goodman Heating & Cooling
My goldstar 6000 btu window ac is dripping into the house
Sounds like you're using it when the outside temp is cooler than the inside temp. when this happens, frost will build up on the condensor. Turn the unit off until the ice melts off with a shim under the unit tilting it back towards the outside of the window to drain. If it continues to drip after melting all the ice off and letting it dry out, you have a small leak in the condensor, (unit must be old or worn out) that the freon pressure has leaked out causing it to condensate more. A good checklist would be to check the level of the unit, make sure the coils are clean and not bent, the age of the unit and for small areas of corrosion or white marks on the condensor before replacing it.
Aug 28, 2011 | Goldstar KG6000R Window Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
What is the power draw (in watts or amps) of the Kenmore 5300BTU room air conditioner? The unit is being powered off the grid by an inverter, and I think the user chose too light weight an inverter for the...
5.8 amps. see page 9 (5300 btu is considered a 6000 BTU, 4800 is considered 5000 btu, sorta like a 2x4 ain't really a 2x4 LOL)
You cannot run an ac on an inverter, not enough juice to get it started.
May 28, 2010 | Kenmore Single Room Air Conditioner
I have a Panasonic 1200 BTU air conditioner, that ...
The ball bearings in the fan motor is toast. Options: 1. Contact your dealer or Panasonic directly. This is a known problem and Panasonic will send you a new fan motor for free or at a reduced price, depending on the age of your unit. You will probably have to change it yourself, or call a tech to do it for you (about 1 hour of work).
2. Change the ball bearing(s) in the fan motor yourself. 1-2 hours of work if you are somewhat handy. Buy a CERAMIC bearing (Size 608, ZZ, Ceramic - the same size you use for a skateboard) @about 10 USD (7 EUR) in your local hardware store. You probably only have to change one bearing, the one on the "inside".
May 20, 2010 | Panasonic Room Air Conditioner CWXC104HU
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Hitachi Madris ac console
Hitachi is a good brand, I wouldn't be afraid of it.
As to the size, it seems a little 'oversized' for the room you're talking about.
24x12 = 288 sq ft. As a general rule you need 12000 btu for every 600 sq ft.
I'm thinking between 6000 -10000 btu ought to be big enough.
Lots of things go into sizing, and the size of the room is important - but the 'heat load,' needs to be considered too. For example - will there be a lot of people in this room, or is there a lot of windows, is there electrical equipment in this room that will be putting off heat, and how well is it insulated? So you need to consider all of these things when deciding what size unit to buy.
For example - if this room is a bedroom and used primarily for sleeping - I wouldn't be afraid to put a 6000 btu unit in it - but if it was going to be used as a place with tv's, computers and other electrical equipment I might want to put a 10000 btu (or larger) in it.
Good Luck!
Generally speaking, it sounds like 18000 btu is too much AC here, and there's no reason to spend more money than you need to and you can 'oversize' just as easy as you can 'undersize' when it comes to Air Condtioning.
May 05, 2010 | Heating & Cooling
Leaking aircon
THERE IS A TUBE OR CHANEL FROM THE FRONT EVAPORATOR DRAIN PAN THAT RUNS TO THE BACK OF THE UNIT INTO THE CONDENSER PAN. IT IS ALWAYS ADVISABLE TO THOUROUGH LY CLEAN ALL COILS, AND DRAIN PANS AND DRAIN LINES ANUALLY. IF THAT TUBE OR CHANEL WAY GETS PLUGGED IT WILL CONSTANTLY DRIP IN THE COOL MODE.,
IF YOUR A/C IS 110V MOST ALL ARE ABOUT 5,000 - 7,000 BTU''S ALL SHOULD RUN ON A SEPERATE CIRCUIT OR NOT HAVE ANYTHING ELES PLUGED IN ON THAT CIRCUIT.
MOST ALL WINDOW UNITS HAVE THE BTU'S RATING ON THE TAG INSIDE THE UNIT. THESE SMALL UNITS REQUIRE COMPLETE REMOVAL FROM THE WINDOW OR WALL FOR CLEANING. ONLY LARGER UNITS 10,000 AND ABOVE SLIDE OUT OF THE CABINENT FROM THE FRONT.
90% OF A/C I HAVE REPAIRED IN 40+ YEARS WERE DUE TO PLUGGED DRAIN LINES A DIRTY COILS. THEY MUST BE ALL CLEAN BEFORE I COULD START TO DIAGNOSE ANY PROBLEM BECAUSE THE PRESSURES VARY IF THE COILS ARE RESTRICTED WITH DIRT, ETC.
Feb 08, 2008 | Heating & Cooling
Panasonic CW-C100AU Air Conditioner Logo
375 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
