Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Water droplets don't evaporate after cycle is over
Why do I still have water droplets on all sides of the dishwasher after the cycle completes? Shouldn't the water droplets be completely evaporated from the drying heat? I even press high heat. I mean the dishes are hot and dry but there is still water on all sides which i feel should not be there.
  • 901 Answers
Refer user guide. Check hot air blower working!
Posted on May 27, 2010
My dishwasher is left quite wet inside after washing dishes. Is this unusual, especially for an expensive Viking dishwasher that is brand new?
make sure you have selected the heated dry option. for the smell, add a 1/2 cup of white vinegar to wash cycle.
Jun 21, 2015 | Viking Dishwashers
Dishwasher not completing cycles
see this causes and fix it. God bless you
If the cycle doesn't complete, check these:Water-heating cycleTimerWater-heating cycleMany dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. TimerTimers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. 9_25_2012_6_48_09_am.jpg
Sep 24, 2012 | Dishwashers
Whirlpool built in dishwasher DU840SWKQO
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 22, 2011 | Whirlpool Dishwashers
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
The dishes, glasses,cuttlery and more have white spots like no well rinse ( at the end of the cycle). I have changed of brand dishwashing and have tried another cycles.
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jul 19, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My whirlpool dishwasher cleans well but once the rinse cycle is completed and drained the next day the washer has water in it. HELP!
it could be a bad fill valve.to chk this ,open the door and look for the inlet hole from where water comes in.if u see and droplets of water coming down the hole then it is the fill valve.when machine is off the fill should be closed and no water should come in.
other thing could be ,if u have hooked up the drain pipe of the unit directly to the food disposar instead of going through air gap mounted at the sink then some water from the disposar could flow back into the unit.units have chk valve valve built in drain pipe but some times they work 100%.also chk 2 c if water insinde unit is dirty or fresh to confirm above things.
Aug 22, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
Dishwasher slowly fills up with water after wash cycle completed
Inside the bottom of the dishwasher under the lower rack to the side there is a float that regulates water level. jiggle it up and down a few times , it will be OK. Vitally
May 12, 2009 | Dishwashers
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Tub still wet/ not drying
YOU NEED RINSE AID ! ! Make sure your selection option is HEATED DRY.Please rate this !
Jun 06, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher does not cycle
Yes, you'll need to replace the motor. Though you may not need to remove the machine from under the counter.
Feb 09, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
200 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
