Question about Kenmore 71121 Air Conditioner
Room air conditioner not cooling low enough
Turned on Air Conditioner first time this am. Had to turn it down to 60 to get it to cool. Does not get very cold. Can you put new refrigerant in it?
  • 420 Answers
It may need cleaning, if it cools when you turn the thermostat down it does not need refrigerant, the unit may have a thermostat our of caliabration.
Posted on May 27, 2010
I cannot get my temp down to 58 but stays at 68
What is the BTU rating of the unit and what size space are you trying to cool down? Air conditioners move heat from one area to another. Possible reasons for not achieving the temperature you want are 1) the air conditioner you are using is too small to cool the size room you have or 2) the space where you are trying to exhaust the hot air from the air conditioner is too hot to allow your air conditioner to move enough heat out of the room you are trying to cool.
Mar 19, 2015 | Heating & Cooling
My frigidaire Air Conditioner model Lra074at7 is not blowing cool air. Its very hot in the room I have it in. Not sure what to do??
Hello friend, thank you for your inquiry!
I understand that your Frigidaire air conditioner is not blowing cool air. There could be many possibilities to why your appliance is not cooling properly.
· Check to make sure the air vent is not in the open position.
· Make sure there is nothing blocking the airflow of the appliance.
· If your appliance is turned on in a hot room it could take additional time to remove "stored heat" from walls, ceilings, floors, and furniture.
Is your appliance under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy. I hope this is helpful. -Matt
Aug 19, 2014 | Electrolux FRIGIDAIRE LRA074AT7 6500BTU...
Blower stays in low...
That will be in the lower motor,the speeds,so to fix the speeds,the motor will have to be replaced.
Jul 24, 2010 | Kenmore 70187 Air Conditioner
I have an LG AC and the lowest temperature setting is 60 degrees
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
May 02, 2010 | LG Heat cool Window Air Conditioner
How can you make your conditioner cool to 40 degrees
ACs are designed to cool down to about 68^F, don't think it has a chance of doing what you want w/o re-engineering the system which is not really an option.
Sep 26, 2009 | Danby DAC9003D Air Conditioner
Airconditioner turns on and off automatically.
It is normal for an air conditioner to turn off and on automatically. This keeps it from making the room too cold. If it has a digital thermostat, set the thermostat to what temperature you want it to be in the room. If the air conditioner has a knob that says "colder", you let the air conditioner run until the room is comfortable to you and then you turn the knob very slowly toward warmer until the air conditioner turns off, and then very slowly turn it back to colder until the compressor comes back on. It's normal for a non-central air conditioner to run the entire time you have the power turned on but the compressor, which provides the cooling, will turn on and off when only when cooling is needed.
Sep 20, 2009 | Samsung AW0603B Air Conditioner
LG LWHD8000RY6 Air Conditioner Not Cooling Room
Remove the front cover of the unit to expose the cooling coil. Put the unit on and observe if there will be formation of frost (ice) on the coil. If there's frost formation, the common cause is dirty cooling coil. Have it cleaned using an alkali base coil cleaner. If the coil is clean, then the problem is the fan motor. It might be turning slow due to copper loss. Have it replaced.
May 28, 2009 | LG Heating & Cooling
I bought a Lg 11,500 btu air conditioner yesterday at home depot. It has been set on 60 degrees with the fan on high and will only bring my room temp down to 79....it does not feel cool
An 11'500 btu Is appr. 1 ton of cooling capacity or enough to cool approximatly 450 sq ft of floor area. Be sure to read the instructions of course and be sure that all the packaging material was removed that may be restricting airflow. On high you should be able to easily feel the air blowing 10-15 ft from the unit and the air should be dropping about 15- 20 degrees when it exits the unit. So if the room temperature is 85 degrees the air exiting the unit should be around 65 -70. The amount of time it takes to cool the entire room depends on how big the room is and how much and the intensity of the heat infiltrating the room and the number and heat output of appliances and people in the room. Hope this helps you out GL!
Jun 11, 2008 | LG Heating & Cooling
Air Conditioner Smoke
The smoke you are seeing is the cold air turning the hot humid air into a cool mist. This may happen when you first run the a/c to cool the room. Once the room is cooled down you should not see the mist any more.
Jul 09, 2007 | Maytag M3V08S2A Air Conditioner
Kenmore 71121 Air Conditioner Logo
258 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
