Question about Ovens
Hotpoint electric oven elemnt won't stop heating even after you turn off and the temp switch
  • 523 Answers
The t stat is bad
Posted on May 27, 2010
Hi I have a Hotpoint Double Oven Model 6181. The Main Oven has suddenly stopped heating up and I suspect the Element has gone. But how do you get the element out? - I can't pull it out and there are no...
Hi.
All you need to do is to remove the screws securing the cover at the rear of the oven compartment.
There you will see the cicular eloement, just undo the fixing screws, and ease the element forward, transfer wires onto new elemnt, , refit, and job done.
Mar 25, 2011 | Hotpoint DY46 Style Line Stainless Steel...
Turbo chef is not heating up, coming up on it reads, f8 low heat
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Jul 03, 2010 | TurboChef C3 Single Oven
I have a double oven top one stopped heating up sooo i just switched the elements from the bottom to the top as to order the parts but that isnt the problem the top still won heat up
This could be a faulty circuit or sensor that will need to be replaced before the oven safety feature will disengage. If the Temp sensor is not registering as working or the load sensor it will not allow the element to heat up. This is a safety feature. You will need a repair tech to diagnose this and do the repair.
Oct 17, 2009 | Frigidaire FEB27S5A Electric Single Oven
After cleaning the top half oven with a self-clean cycle the oven will not pre heat past 100 degrees. The bottom oven will heat. What might be causing the top to malfunction? The serial number is...
usually it is the thermal cut off( TCO) ,a kind of themal fuse which goes out if the temp exceeds certain limit and cuts off the power to the elemnts.it is to protect the cavity from over heating.it needs to replaced or reset depending the model. u will need a tech to fix this.
Aug 21, 2009 | Electrolux Ovens
Hotpoint BD52 oven very slow to heat up
You may have one leg of power that is out. First turn off the breakers, then back on. Check it to see if it is better. Then check the wiring from the receptacle, to the plug, to the back of the oven. Look inside the back of it and see if you see any fuses. They could be blown as well. If you are getting some heat (red) then it is an indication of a wiring or fuse problem. Now, one last thought here, if you turn it to high heat does it heat up faster? This one lead it to be in the control switch. Let me know how you do.
Feb 13, 2009 | Hotpoint Ovens
Oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
