Question about Tunturi T20 Folding Programmable Treadmill
Where can I purchase a teflon spray lubricant for treadmill?
Where can I purchase a teflon spray lubricant for my Tunturi J661F treadmill? If this is not available can you recommend a suitable alternative? This treadmill has a teflon treated running belt and the lubricant must be non silicone. Thank you,
Declan.
  • 1 more comment
  • Anonymous Mar 25, 2014
    how to lubricate my running deck of my treadmill
  • Rick Hantz
    Rick Hantz Jun 18, 2014
    Amazon.com has teflon lube spray by Dupont. I just ordered a can. Should work, no silicon to degrade the belt.
  • rickhan Mar 06, 2016
    teflon spray doesn't work, you need the wax.
  • 15 Answers
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
Tunturi t80 treadmill gives check lubricant message after multiple times of lubricating the belt
RESET the machine. Use your owner manual read section troubleshooting and proceed according.
God bless you
Aug 02, 2012 | Tunturi T80 Treadmill
Where can I obtain the belt lubricant for my Tunturi T20 treadmill?
go to www.fitnessrepairparts.com or www.unitedassemblers.com
God bless you
Jul 14, 2012 | Tunturi T20 Folding Programmable Treadmill
Tunturi j661f instructions for use
Dear Sir:
Go to the next web pages>
www.fitness.manualsonline.com or www.iconservice.com for download free. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 16, 2012 | Quantum ® 3.2EX Treadmill
What lubricant can i use for my pro form tredmill model 380 E?
You can use silicone lubricants.
But if you want buy lubricants:
go to www. treadmillpartszone.com
or www. gympart.com
sincerely.
E.CUADRA
MANAGUA,NICARAGUA. C.A
Nov 23, 2011 | Tunturi T20 Folding Programmable Treadmill
My tanturi treadmill model j620p indicate 51 in the panel. even i press the reset button still the 51 still in there. all keys does not work too. what shoul i do?
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING
THE RUNNING DECK
Please apply teflon by using the pressurised can provided
with these instructions.
1. Let the treadmill run at a slow speed and spray
teflon into the lubrication .
2. When teflon is applied for the first time,
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
My tanturi treadmill model j620p does not work. thou it has a power n the panel indicate a number 51 even i press the reset button it does not reset and all the key button does not function. what sould i...
Dear Sir:
turn it on again.
rail).
4.3. LUBRICATING
THE RUNNING DECK
Lubrication is the most important service activity for the
treadmill. This is absolutely essential, if the friction of the
running deck increases noticeably or the motor begins to
heat up. Lubrication intervals must under no circumstances
exceed 200 usage kilometres; we recommend relubrication
once a month. During the first 200 km of use, the running
deck must be lubricated at intervals of 50 km. Insufficient
lubrication will cause the belt, running deck and motor to
wear out and break.
NOTE! Before you start to use your treadmill, it must be
carefully lubricated per the lubrication instructions
below! NOTE! If the treadmill is not used for at least
three weeks, it must be carefully lubricated per the
lubrication instructions below!
The need for relubrication depends to a great extent on the
running styles and weight of the user: heavy user weight and
slow speed put particular strain on the device and therefore
demand greater lubrication. Use only the teflon enclosed to
lubricate the treadmill. Contact your local TUNTURI dealer
for further supplies of teflon.
NOTE! The device must under no circumstances be
lubricated with silicone!
instructions on the teflon bottle carefully.
teflon into the lubrication pipe underneath the
treadmill. The pipe is marked with a decal.
2. When teflon is applied for the first time, the
spraying time with the pressurised can should be
approximately 20 seconds. Later, a spraying time of
10 seconds is sufficient.
3. Teflon drops through the holes of the lubrication
pipe to the center of the running belt; the treadmill
is instantly ready for use.
Please ensure after each time that you relubricate your
treadmill that a strip of about 8" wide on the underside of the
running belt becomes moist with teflon oil along its whole
length. If necessary,
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
Need lubrication for proform 785 belt
Some ProForm treadmills require lubrication every six months or so, depending on the usage amount. Lift the walking belt and feel on the underside of the belt. If it is dry, you should lubricate it. ProForm recommends you use 100-percent, non-petroleum silicone spray to lubricate the walking belt. Do not use wax or other lubricants, such as WD-40 or a Teflon-based spray
Aug 24, 2011 | Proform 785 Treadmill
I have a horizon RST 5.6, the screen is reading lubricate belt- how do i do this and what with?
hi,
You can lubricate the treadmill with Teflon Silicone Spray.To know how to lubricate the teradmill watch the following video.
Aug 06, 2011 | Horizon Exercise & Fitness
When I turn on the treadmill, after runinng for a few seconds, the belt makes a squeaky sound, as if it needs to be oiled up or needs adjustment. What can be done to fix this? Any suggestions are greatly...
The best recommendation and the most inexpensive would be to lubricate it. Do not use a silicone spray or anything with silicone in it. You should us a waxy lubricant or teflon based. Most specific treadmill lubricants suffice. If the sound is coming from the front of the machine then I would check the drive belt that goes from the front roller to the motor. These are 90% the causes of the sound. Lubricating and tightening generally corrects the problem.
Aug 15, 2010 | Proform 5.0 Crosstrainer Treadmill -...
Tunturi T20 Folding Programmable Treadmill Logo
2,191 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
