Question about Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS
I have the sama problem...err 1... clean the lens contact... I tried it did not worked...any other solution
5 Suggested Answers
  • 3 Answers
SOURCE: Err 01 during slow shutter speed shooting
I having a similar problem and send back to the Canon service centre for repair. Subsequently, it was confirmed that the aperture diaphragm is faulty and need to be replaced.
Posted on May 13, 2009
  • 9 Answers
SOURCE: I am trying to use an older SIGMA 28 - 200 mm f3.5
To NOT get that error you need to use in AV mode. It's the only way that old Sigmas work with the new Canons. It's an aperture bug that old Sigma lens have and some the only way to fix it is to rechip it. The problem is that Sigma no longer rechips the lens.
Posted on Jul 03, 2009
Obertelli
  • 3006 Answers
SOURCE: Canon Zoom Lens EF-S 17-85mm 1:4-5.6 USM: I
I hate to re-invent the wheel (and I don't want to cut 'n paste someone else's hard work to present as my own) so please click here for a likely practical solution which usually works and for Canon's own suggestions on the error 99 fault.
If this has assisted you then please rate my answer; if not then add a comment to provide feedback and I'll attempt to provide an alternative solution.
Posted on Mar 02, 2010
Tri3mast
  • 747 Answers
SOURCE: have a canon 17-85mm USM lens. when taking photo
That's a really odd fault and to be so specific in focal ranges is a further oddity which makes me wonder if it's the mount having a slight bit of movement (slop) in it.
I have that very lens and use it regularly about a year ago I sent it to Canon for some minor service when it came back it had a different "feel" the lens was tighter in operation.
Would it be possible you need to clean the gold contacts on both the lens and body (I know you said it wasn't the contacts) with a red rubber eraser making sure not to get the rubber dust into the sensor area. Then watch the lens as your shift through your focal lengths to actually see if the lens is moving slightly between the lens and body. Make sure the lock is in tight with a distinct click, if all this fails then I'm sure a trip to Canon is in order, it's a great lens and worth the repair.
Posted on Jan 06, 2011
I keep getting Err 01 and no photo is taken what do I do?
ERR 01 is a lens to body communication error. Clean the lens and body contacts (put a small amount of alcohol on a Q-tip - do not use rubbing alcohol!!!). Try again. If that doesn't work, problem may be in lens or body. Using the flat of your fingernail, push in the contacts on the body inside the mirror box to clean any tarnishing between the contacts the the circuit (they are spring loaded). Try another lens - if the other lens works, then your problem is in the first lens. If it still gives the ERR 01 code then the problem is in the body.
Has the camera been impacted or had water/liquid spillage?
Sep 16, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Err 1 message
Err 01
Description: The communication between the camera and lens is faulty.
Resolution: Very gently clean the electrical contacts (highlighted in red) on the camera and the lens using a clean and dry cloth.
Mar 24, 2013 | Canon EF 75-300mm Lens
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
May 25, 2009 | Canon Cameras
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Dec 16, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon 300d gives error 99 and does not work
Try the following diagnosis steps: -
Nov 28, 2008 | Canon Digital Rebel / EOS-300D Digital...
Hi, my canon 300d gives error 99 and doesw not work
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Open Questions:
See all Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens Questions
Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS Logo
70 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
