Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Oven door locked after cleaning
How do you remove the locking unit
  • Reinhard May 04, 2008
    Same thing on Jenn-Air SVD48600P.
    Ron
I have a kenmore self cleaning oven. I Locked it
and have held the cleaning button for 3 secs and
returned the lock lever to unlocked position and the
locking lever in the inner of the oven door is still ingaged i have tryed to manually push the lock with a object you can feel it move over but the door still will not open. door will come out an inch.
Posted on Sep 06, 2008
3 Suggested Answers
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
Solution #3 was very helpful. Took off the back panel and found the small black fuse. Removed the fuse and joined the two black wires, oven now turns on and oven door opens. Don't think it would be to safe to leave like this but going to get the part and put the fuse back in myself. Very easy to fix (just a million screws) so save yourself the expensive service charge!!!!
Posted on Apr 14, 2010
jonniewalker
  • 1031 Answers
SOURCE: Self clean oven door lock
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Posted on Sep 09, 2008
DOOR LATCH IN LOCKED POSTION WON'T RELEASE
try to press and hold the clear off key for three to five seconds.you may need to remove the back panel and remove the door lock mechanism in order to release the lock try unplugginf the unit for a couple of minutes as well
Jun 22, 2010 | Frigidaire FEB27S5A Electric Single Oven
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
My oven lock is on and will not come off
you can hold the clear/off button for 3-5 seconds this hsould realse the lock.if not you can temporarily remove te back cover and remove the motor.sometime unplugging the unit may relase the lock
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The lock light is blinking, the door is locked, everything is turned off, and the temperature is definetely below 490. We cannot get the door to open. I have a E36DF76EPS model
Hi
Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 26, 2009 | Cooktops
My oven is locked and wont open. it is cold and wont unlock
Hi
Thanks
Rylee
Nov 25, 2009 | Maytag MER5775Q Electric Kitchen Range
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
Self clean oven door lock will not unlock accidentally pushed clean button, cancelled clean but oven door will not unlock. it's been two days now.... what should i do? tried unplugging unit, that...
Sep 09, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How do you clean self-cleaning Maytag Gemini?
If the unit is a self-cleaner, you should remove everything from the oven (including the racks as the self-clean mode will remove necessary lubrication from the racks if left inside). If the range has a slide lock on top of the oven door, move it from left to right to lock the door, then press the self-clean button. If it does not have a slide lock, it should have a magnetic lock which will engage when the self-clean function is activated. The oven will reach approx. 800 degrees for about 3 hours. When it cools, you should see a white powdery substance in the oven. Wipe this up and you are done.
Mar 22, 2008 | Kitchen Ranges
Oven door locked
unplug unit and plug it back in if that does not reset the locking assembly.Unplug unit remove back panel and look for the locking assembly.It will have a rod that goes to front where door is.Remove locking assembly to release rod and replace locking assembly.
Nov 24, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
159 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
