Question about Hitachi C18dl 18v Cordless Circular Saw Tool Only
Cut the cord and replaced it but saw still doesn't work
  • Al Kupchella
    Al Kupchella May 27, 2010
    How far back did you cut the cord? If you suspected the cord to be the problem, the point of failure is usually right where the cord exits the saw, so you would have to disassemble at least the handle of the saw and replace the entire cord. You can usually re-use the strain-relief rubber jacket that protects the cord in this vulnerable area.
  • gclark11 May 27, 2010
    I disassembled the saw and replaced the cord, but it still doesn't work-
    Problem Solver:
  • 15 Answers
Maybe the positive and neg. wire's are turned around....switch them around and see if that works.
Posted on Jun 08, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: how do i replace the pull cord on my stihl cut off saw
it is gonna take some time,take all screws off housing,pull casing off,be careful with the rewind spring and be sure you have spring wound-up for re-install.
Posted on Apr 24, 2009
The power cord cut open where it goes into the plug. Is there a replacement plug with a cord attached that would replace it?
i use any cord that can be salvaged off of other appliances that are thrown out. i can make anything work
Oct 31, 2013 | Microlux gourd / cross saw
Erratic starting circular saw
Sounds to me like you have a bad cord. Clamp the saw to a workbench so that it can start and run safely without you having to hold it. Put tape or a wire tie around the trigger to hold it in. THEN plug it in. Then move the cord around, especially near where it enters the saw. If the saw starts and stops intermittently you have confirmed the bad cord. Good luck.
Mar 06, 2013 | Saws
Tile saw wont start. It's brand new. Is there some sort of safety device.
The first thing you should check is the GFCI switch on the power cord. All tile saws have one because of the water involved with cutting tile. It should have a test and reset button on it, press the reset button to get power to the saw motor. Some bigger saws also have a reset button on the motor itself for overload issues. Check for that if the GFCI reset doesn't work.
Jun 02, 2012 | Saws
I have an Star Diamond PF-10 lapidary saw. The power feed doesn' work.
I have the same saw but the saw bearings are shot. I'll sell you the top with the working power feeder if you are interested. Or does any one have a solution to replace the bearings. they are built into the shaft abd looks not to be replacable
Brad 612-382-4762
Nov 27, 2011 | Garden
Can the cord on a Circular Saw be replaced? By whom?
you can replace it your self . you can cut cord shorter and put on a new plug. @ home depot you can replacement parts
Nov 15, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
Cut off saw stopped working cord has power could it be bushings?
more likely it is the brushes, there should be two plastic plugs on the side of the motor case with slots for a screwdriver. remove the plugs and take the brushes out. they should have a replacement number on them if not the user manual may list them
Sep 25, 2011 | Craftsman 14 in CutOff Saw
While checking the intake tube the power cord got on the wrong side of the cord so when I turned the saw on it cut the power cord. Can I get that replaced?
Yes, it will require that you "crack" the case, but it isn't that difficult to do. Suggest wire ties so that you don't have to do the replacement very often.
Jul 15, 2011 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
May 03, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
10'' Sears MITER saw cord nick cut 1/3 way through 1 copper wire.
as long as the wires are intact it is still double grounded and yes you can replace the cord, as to not working sounds like a wire is broken
Mar 15, 2009 | Saws
Cordless or cord saw Comparison
Cordless tools lose power as the battery drains, while corded tools deliver reliable, consistent performance with unlimited run time. Corded reciprocating saws range from less than 5 amps to 15 amps or more, with more than 10 amps providing optimal power for heavy-duty commercial use.
Aug 27, 2008 | Hitachi 11A Motor, Reciprocating Saw,...
Hitachi C18dl 18v Cordless Circular Saw Tool Only Logo
76 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
