Question about HP Compaq Presario SR2010NX PC Desktop
Compaq Desktop won't boot up.
My mother's Compaq Desktop won't boot up. It is a SR2010NX running Windows Vista. The fan runs but I can't hear any thing from the hard drive. I believe the hard drive is bad. Is there anyway to test it before replacing it?
  • 903 Answers
Do you have your Vista installation disc? If so, you can boot from that and then run the Windows RE troubleshooter, which should be able to test your hard drive and maybe even try to repair it.
Posted on May 27, 2010
Testimonial: "I have the disk and will try it. Thanks you for the info."
  • 128 Answers
Hi maj
firstly you need to hear if there is any kind of noise made by your Hard disk ( this is to check if it has been physically damage)
two option:
1.then to check if it has some bad sector, you need to remove to hard disk and use it as an external harddisk or a secondary hardisk in another computer, there you can go in Accessories in your start menu and try for disk check
2. you will need a bootable cd say 98se, then boot with cdrom support,then you can run chkdsk command on your command prompt that is commonly C:\
both the options will was you if your harddisk is having bad sector or not
happy computing
Posted on May 28, 2010
Testimonial: "I will try these. I didn't think about using the HD drive as a secondary. Thanks"
Need a boot driver
If your computer came with recovery media, you'll want to insert and boot from the operating system install disk (if it doesn't boot from your media automatically, you may have to change the boot order in BIOS [hit f10 at boot time]. Depending on the version of windows you are running, the boot options will be slightly different but you want to end up in repair mode. in XP that will mean hitting "R" to repair, vista/7 you will hit "repair my computer". Once you can get into a recovery console, you'll want to type: sfc /scannow
That will find and replace corrupt system files and boot drivers.
Nov 07, 2013 | HP Compaq Presario SR2010NX PC Desktop
No boot drive
you can check the hard drive connection's first (sata or IDE)
try to tighten the connection and try to reboot your system
the if it still doesn't work try to download a hard drive utility tools
like hiren boot cd and scan your hard drive for bad sectors and repair it if posible, for further question post your detailed problem here
Hard drive not being recognised by compaq presario SR1975AN on warm boot
The hard disk may be running too hot.
The desktop case inside temperature maybe too hot. Check the power supply fan/CPU fan are operating correctly. You may need additional cooling in the desktop case an additional fan near the hard disk.
Mar 23, 2012 | Samsung SA07HD103SJ Samsung HD103SJ 1 TB...
Compaq CQ4010F Desktop PC won't turn on after a power surge
You probably and lets hope so, have an Electro Static Charge Buildup on your desktop. Remove the Power Cord and Press and Hold the Power Button for 30 seconds. After 30 Seconds plug the Power Cord back in the hit the Power Button. If it boots then you had an Static Charge Buildup. If it does not boot and you say it happened after a power surge then either your Power Supply or Motherboard is possibly damaged. Do you hear fans, hear the disk drive running, see lights, hear the CD Rom click once and see the light on the CD Rom drive com on briefly after you hit the Power Button. If so it would seem that your power supply is ok.
Mar 18, 2012 | Compaq CQ4010F Desktop PC (NY650AAABA)
I cant install windows 98 se in a computer compaq 900 series because i lost its installs disk they were 2 and i install from another cd all is great but when it restart goes black with a mesage "...
Hello Pushan, can you send detailed specs of your system, meanwhile try the following:
1. Is the hard-drive empty or formatted? if so then you need to create a partition first:
- start your pc using ur cd if it is bootable (you'll know if it loads some drivers first), if not get a bootable cd
- Run fdisk (type fdisk at the command prompt) and create a primary partition, reboot & format
2. Boot again using your cd, when done switch to the win98se directory and run setup
Thanks for sharing, let me know how it goes
Jul 01, 2011 | HP Compaq Presario SR2010NX PC Desktop
My compaq presario sr2010nx desktop won't turn on. I tried fooling with the off/on switch wiring and it came on for a short time. All was well. I hadn't used it for a week and tried to turn it...
Hi.
Sounds more like a power supply problem. First test the on/off switch by tracing the wires to where it connects to the mother board. The plug is usually marked "pwr sw" . Unplug the wire from the board & short out the 2 pins where the switch was plugged in using a small screw driver or any other conductive material. If the pc still fails to turn on, try replacing the power supply.
Best wishes,
Graemevm
May 10, 2011 | HP Compaq Presario SR2010NX PC Desktop
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
HP Compaq Presario SR2010NX PC Desktop Logo
398 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
