Question about Zanussi ZWF1430W Front Load Washer
Have a zanussi fr1450ow washing machine it spins but does not empty i think it has a blocked outlet pipe how can i disconnect from under machine to clean it out?
  • Zanussi Master
  • 909 Answers
Exactly so. Remove pump and clear impellar for any obstruction. Replace
Posted on May 27, 2010
My machine won't empty
blow through your outlet pipe and see if its blocked. and clear your water trap if it has 1
Apr 26, 2015 | Hotpoint WMTL79 Top Load Washer
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
My machine wont drain or spin. if i maually empty, it will eventually start a wool wash but then says error e20 but filter is clean and no kinks or blockage in drain pipe. should i replace outlet pump?
Do the following.
1. Switch off the machine, unplug or disconnect the mains AC power to the machine and turn off the water supply to the machine.
2. Remove the filter access panel.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Nov 13, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
My Zanussi FLA1001W will wash but will not sin or
Check the impeller on the pump free to move. if ok check electrical connections. if ok either pump is faulty or it could be main pcb (or both)
Oct 17, 2009 | Zanussi FLA1001W Front Load Washer
Zanussi washing machine
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi IZ161S Water filling problem
Check the drainpump. It may be clogged with lint or something, or blocked.
Jan 14, 2008 | Zanussi IZ161S Front Load Washer
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
Water in machine under bucket
your outlet hose put it down close to the floor into a bucket if water comes out then your pump may have blown if not it will be blocked up u may find if u take the outlet hose of water may come out which means your pipe is blocked
Aug 12, 2007 | GE WJRR4170E Top Load Washer
Not Pumping out water
Possible your outlet filter is blocked. After disconnecting electrical input from wall socket, remove the back panel of washer to see if the pipe from the tub is blocked, clear, also check the outlet filter, clean. If u have the users' manual check how to clean your outlet filter
Nov 14, 2006 | Creda W120VW Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
61 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
