Question about Microwave Ovens
Display panel shows E01 and bleeps continuous
  • Microwave Ovens Master
  • 9,085 Answers
A model number would help, but one Sharp commercial manual lists these codes as close to what you typed:
"EE1" Magnetron (1) failure. (could be one of many parts in the magnetron 1 circuit)
"EE0" Fan lock judge.
"EE10" Intake thermistor is shorted.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please post a new help request with your model numbers and precise symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 28, 2010
GE Spacemaker XL 1800 Microwave. After removing heated food, I closed the door and the microwave sounded like it was powering up again. However, no internal light came on as it does when the unit is...
Be sure to keep this oven unplugged or the door open until it is fixed. If it runs by itself, this is a fire hazard.
First listen carefully for a buzzing sound behind the control panel when the door is shut.
If it's present, chances are you have a failing capacitor on the control panel assembly, which can be repaired for $39.95 in most cases. Details are here.
If that or a louder buzzing is only present when you have the door closed, then the oven is cooking when it's not supposed to, but the cooling fan is not on, and it is overheating and tripping the breaker.
That would be due to a shorted cook relay on the control board. That can also be repaired with our $39.95 service.
The odd characters on the display concern me separately. This could mean you have a noisy or otherwise failing magnetron.
If the display is fine when you're cooking properly with it, then the magnetron is probably okay.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Apr 28, 2011 | Microwave Ovens
I have the West Bend #84386 and every time I push the power button, E01 shows up in the display window.
It is showing Some sort of Error like Fuse Blown or element Damaged or Voltage Problems etc
please Rate my answer and Support me
Nov 21, 2010 | Microwave Ovens
When microwaving with my cad cm4ss microwave. after a minute or two it switches off and shows E01 It does not happen every time. Any idea what the fault may be
Error 01 is usually magnetron failure. I suspect the connections to the magnetron may be poor.
Watch out as lethal voltages are at that point!
Nov 09, 2010 | CDA Microwave Ovens
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
Microwave - Explanation of the Child Lock Out Feature
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day.
A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
Sep 13, 2010 | General Electric Microwave Oven
My Sanyo EM-D975 starts and then stops after 3 seconds with E01 on the display, i pressume this means error 1, can anyone help
I would first suggest that you check the door switches and switch holders. See this file.
If it is equipped with an inverter, that may be the trouble.
You can locate Sanyo owner's manuals, part distributors and authorized servicers here.
Good luck.
Jan 30, 2010 | Sanyo Microwave Microwave Oven
Microvawe whirlpool vt 255 problem
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Aug 29, 2009 | Microwave Ovens
Panel displays F6; continues to hum. Will not re-set after unplugging..display continues to show F6.
F6 is a shorted cook relay on the control board.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Jul 11, 2009 | Microwave Ovens
Hinari lifestyle combi microwave oven. After being stored for some time, this unit displays E=01 and bleeps continually. Can't get past this for it to work.
Hi, I don't have a solution, just the same problem! It says you had one solution to your question but I can't see it any where. Is your hinari working now?
A.I.
Jun 13, 2009 | Microwave Ovens
Microwave bleeps and display shows F3
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
Feel free to contact us with your full model number and we can tell you if yours is one of these models, and if so, we'll also give you the part number you need to order and a link to the best priced supplier.
prototech@usa.net
May 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
179 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
