I have a 2004 Chevy Tahoe with dual zone air conditioning plus rear air conditioner. My problem is on the 2 driver vents only it keeps going from cool air to hot air. After you drive for a while it is all hot air coming out of these 2 vents. All the other vents (passenger & rear vents) are blowing cold air.
  • 767 Answers
If the truck has a dual zone temperature control in the center console then this is most likely your problem as alot of times when these go bad the think the driver side is too cold and turn the heat on to warm it up thus giving you warm air through the vents on the driver side.
Posted on May 27, 2010
I have a 2003 Tahoe and when I put the heater on only the driver side get warm passenger side blow cold air
2004 Chevy Tahoe. Hot air out of vents on driver's side, cool ...
answers.edmunds.com > Edmunds Answers
Jun 25, 2009 - Hot air from vents-driver side and cool air from vents on passenger side. ... The driver's side vents were blowing out hot air, and everything else wasblowing cold. ... you'll literally have to restart your tahoe/yukon at every traffic light to keep cold air coming ... I was also getting air only out of the defrost vents.
Hot air out front drivers side vents 05 escalade - YouTube
? 3:14
https://www.youtube.com/watch?v=5lnd8UNcx6M
Aug 3, 2013 - Uploaded by South FL Mud Club
Suddenly hot air started blowing out the air vents only on the drivers... ... is a very helpful video ,I wondering if this part number apply for my 04 chevy tahoe? .... I have cold air out of thepassenger side, but warmer air out of the driver's side. .... 2003 Tahoe No Rear Heat Fix, Suburban, Yukon XL Repair!
Heating and AC Temperature and Air Delivery Mode Door ...
repairpal.com > Problems > Chevrolet > Tahoe
Driver/passenger air vents blow hot then cold when using A/C. Back to cold when you restart the vehicle. Upvote (35) ... 2003 Chevrolet Tahoe ... I have a 02 Tahoe ,and the heat system is working only on the ceiling side of the car when turn.
2004 Chevrolet Tahoe Blows Hot Air - Sparky's Answers
Jan 21, 2016 | Cars & Trucks
2004 tahoe Air conditioner blows weak
Could be blend doors not operating correctly
ButI'd guess the blower motor or resistor is go in outd
Sep 03, 2014 | Cars & Trucks
Had headliner recovered in my 2004 Chevy Tahoe, now rear vents won't blow air through. What happened?
When the headliner was recoverd they probobly had to remove the whole headliner and when it was installed its a possibility that the ducts are not aligned properly for the a/c vents.
Sep 12, 2013 | 2004 Chevrolet Tahoe
The drivers side AC vents of my 2005 chevy tahoe started blowing hot air today. The rest of my air conditioning is running fine (passenger side and rear vents). Is this a thermostat issue and is it...
More than likely the problem is with one of the blend doors or its actuator motor inside the HVAC unit in the dash. The repair involves a partial disassembly of the dash to access the parts. This definitely not a thermostat issue.
Mar 30, 2011 | 2005 Chevrolet Tahoe
2005 tahoe dual climate control, driver side blows HOT air.
You will need to replace the drivers side temp actuator. It is available at your local dealership.
Aug 30, 2009 | 1999 Chevrolet Tahoe
2004 Dodge Ram 2500 air conditioning
It sounds like your electronic vent actuator has gone bad, it's common to go bad and may need to be replaced. There are tinny gears that wear out and the vent actuator stops working. You can try this, turn the radio off first so you don't have to enter the reset code to activate your radio. Disconnect the battery for 30 seconds and reconnect it, if the actuator has lost it's base line and stuck in the open heat position, this will reset it, just make sure the setting is to cold and off before disconnecting and reconnecting the battery. If this does not work, then it's a bad actuator and Auto Zone should have the part you need and will have the step by step instructions for you to the job you self, I believe the dealer is a $415,00 repair cost for this. Good luck and keep me posted.
Jun 22, 2009 | 2004 Dodge Ram 2500
Air conditioner blows colder for the passenger side
It maybe low on refridgerent or your temp sensors need replacing. You could also have a flap problem.
Jun 13, 2009 | 2007 Chevrolet Tahoe
96 chevy tahoe, passenger side and rear cargo carpet is wet
sounds like the air conditioning drain for condensation is plugged
Apr 24, 2009 | 1996 Chevrolet Tahoe
2003 Chevy Tahoe
Its probably the temperature actuator located in the right rear interior
Jun 17, 2008 | 2003 Chevrolet Tahoe
Heating & Cooling Logo
575 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
