Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other times it does not light. Each time it takes about 1 minute before it tries to light (click). Any idea what could be the issue?
  • 3 Answers
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
Posted on May 29, 2010
My Hayward H400 will not turn on
Does the heater sound like it is trying to fire? (Fan on, clicking sound). Check your filter pressure. If it is high, it may be causing the heater not to fire because the heater doesn't know the pump is running.
Apr 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
Haywood h400 pool heater, flames coming out of flue
check gas if ok clean burners make sure it is a propane unit if a N in model number it is natural gas orfices incorrect and will overheat very dangerous
Sep 09, 2012 | Hayward H Series Pool & Spa Heater 400k...
Can an H150PI pool heater be converted from propane to natural gas
On this heater, the conversion may be a kit that replaces all the orifices. In any case if you call Hayward technical support they should be able to provide the correct solution. I hope this helps.
Jul 27, 2011 | Hayward H-series Electronic Gas Pool...
WONT STAY LIT. FLASHES IF
Is this a millivolt or electric ignition heater? You can tell by the connections: gas only = millivolt, gas + electrical conduit = electric ignition.
Sometimes people ridicule us for asking the obvious, but I thought this would be helpful: 1) Are your operating the heater with the pump running? 2) Is the gas to the heater turned on; either at the propane valve (is there propane in the tanks?) or is the valve at the meter for natural gas in the on position.
IF
is the code for ignition failure on Hayward Heaters. This could be related to a bad igniter or plugged burner orifices. Failure often indicates that the sensor wire to the ignitor is bad, rather than the ignitor itself. Inspect this wire, and if the sheathing is cracked or worn, replace it.
If the gas pressure and supply is OK, the proper order for parts replacement would be:
Sensor wire, then the ignitor, then the gas valve.
To inspect the igniter for operation, remove the igniter and turn the heater on and watch for a spark (don't hold it, you'll get zapped!). If you don't see one, try adjusting the spark generator relative to the metal ground around it. Clean out the area where it mounts as best you can.
We have serviced similar issues several times where spiders or debris actually kept the spark from reaching the gas.
Check here for manual and diagrams on all Hayward products
http://www.haywardnet.com/inground/products/manuals.com
I hope that this helps! Please take a moment to give us feedback on the information that has been provided. We all volunteer our time and expertise to help you all out and th biggest compliment is the referral of your friends to the website and feedback from you!
The Ugly Pool Guy www.WeFixUglyPools.com
Dec 13, 2010 | Hayward H-series Electronic Gas Pool...
My plumber needs manual for Hayward #H400 FDP
The P at the end stans for propane...the manual found here is for the H400FD series natural gas or propane.
John
May 31, 2010 | Hayward 400FDP Universal Series Low Nox...
I'm trying to start-up a Hayward H400 natural gas heater for my pool. It was brand new last season and worked perfectly. It keeps firing up for a little while (maybe 10 seconds on average) and then shuts...
if means ignition failure check that gas is on, check for fauilty igniter wiring or connections, inspect gas valve wiring measure voltage across gas valve during trial to ignition if 24 volt replace gas valve if no 24 volt replace control module
May 19, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H400 will not ignite
Gas valve.
Gas valves will often stick in the closed position especially after sitting dormant for a period of time.
if you want the posibility of one more season, You can try to tap on the bottom ans side of the valve with handle of a screw driver while it tries to ignite. Note: This is a technician trick, most manufacturers will not approve in fear you are so lacking in common sense you will go out and beat the valve with a hammer, then sue them when it cracks the metal valve leaking gas while you smoke a cigar ultimately relocating your heater on top of the neighbors Buick..so please don't do that. BUT, If the valve opens and heater fires with a few love taps try it a couple more times to see if it will work on its own. It will likely continue to work if so.
You will likely need that gas valve next year anyway.
Apr 25, 2017 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
171 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
