Question about Kodak EasyShare DX7590 Digital Camera
Broken button on rear panel - Kodak EasyShare DX7590 Digital Camera
    Novelist:
  • 178 Answers
Good thing you are thinking of fixing, these tend to escalate into other things.
http://www.teleplancamerarepair.com/manufacturer/repair-camera-model-problems.asp?mo=408
they can repair and clean your camera at the same time!
place order today, june 3 at this link below and use promo code MD2010 for discount
www.teleplancamerarepair.com/md2010
Posted on Jun 03, 2010
Driver side
sounds like a shorted wire. look at the main cable that goes through the door for damage. the window button could be loose or broken. you might be able to buy just the single button or you may have to buy the whole panel
Mar 07, 2014 | 2002 Ford Explorer
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Trunk latch broken won't open hatchback, how can I remove panels to access for repair
Most often, access to the trunk is achieved by folding the rear seat down. If not, remove the seat and you'll have access to the trunk area.
If access isn't a problem, get yourself a plastic panel removal tool set from parts store and make sure it's not cold when you remove the panels as they'll be more likely to break from being brittle from the cold. Take your time.
Nov 28, 2017 | 2000 Honda Civic
My sony kp57wv600 will not turn off. none of the buttons on the front panel work at all what should i do ?
Hi Jimmy,
Have you try using remote commander? It seems the power button on your tv is broken. It could be on button pad, or cables connected to it. Can you try check it?
Regards
Oct 29, 2011 | Sony KP-57WV600 57" Rear Projection...
None of the buttons on the driverside door panel on my 2002 gmc envoy work
Some possibilities are; Fuse #10 in rear fuse panel, bad DDM (Driver's Door Module) or a broken wire in the wire harness that goes between the body and the door.
Sep 14, 2011 | 2002 GMC Envoy
61md10 61 in. Rear Projection HDTV by inFocus. Screen is black and menu buttons flash on and off a few times. No picture comes on. Any advice?
Could be as simple as a burned-out lamp, but flashing buttons on the panel mean that it's trying to tell you something's broken, so it might not be just the lamp.
You, sir (mam?), need a manual, or somebody who has one. I do, but it's at home. Perhaps if you responded with how many times the lights flash, I could look it up...
Jan 11, 2011 | InFocus ScreenPlay 61" Rear Projection...
Door lock won't lock/unlock with power button
I would think then, that it has to be a broken wire somewhere. Probably in the door jam of the door that doesn't work, or possibly inbside the door. First thing is to see if you have power back to it. Hook a test light up to the power lock inside the door. When you hit the button at the driver's door, it should light up. It could also be a rod has come apart in the door, or broken. You'll have to remove the inner door panel to investigate.
May 16, 2009 | 2001 Honda Civic
Timer
You probably have a broken belt. Remove rear access panel usually about 8 inch square vented and look in to see if your belt is on the motor pulley. If it's broken you'll know it. Good Luck. Post bac if it's not broken.
Mar 01, 2009 | Kenmore Dryers
Rear defogger
check grids along rear window to check for broken lines and check wires on both sides of glass where connections are.
Nov 29, 2008 | 1991 Oldsmobile Cutlass Supreme
Chanel button or sony kp-51ws510 51 in rear projection
the circuitry within the TV is where your problem is. thats why your remote wont work it either. Could just be he wire arent pluged in completely or you could have a bad resistor on the control panel PC board. Hope this helps. Let me know if I can assist you any further.
Jan 22, 2008 | Sony KP-51WS510 51" Rear Projection...
Kodak EasyShare DX7590 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
