My central air conditioning has begun to make a high-pitched whistling sound whenever the compressor outside is on.
  • ericutsler May 27, 2010
    The central air unit is fairly old but has never whistled like this before...very annoying!
    Thanks...I'll give it a try!
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. First thing check the filter inside the house to be sure it is not plugged. Most times the whistling is from restricted air flow. Also if the whistling is coming from the outside unit then use a garden hose to spray through the outside unit coil. Make sure the unit is off and use the hose on jet and spray the water through the fins on the coil outside.
Posted on May 27, 2010
    President:
  • 4,070 Answers
Hi! May I ask how old is your air conditioner? The whistling sound is kinda normal specially when its old. No need to worry. Hope this shed some light.
  • dj_relly999
    dj_relly999 May 27, 2010
    Try replacing the oil, may resolve the noise.
Fan making high pitched whistle
check for debris in the air intake. I've had leaves in mine make a similar noise
Nov 14, 2016 | Cars & Trucks
High pitch whistle sound on my 2005 saturn ion whenever my car is on, whenever it is in idle or in drive
start in the engine bay
look from air filter to throttle body for any air intake leaks
if it is supercharged listen to the supercharger bearings
then anything spinning at high rpm from the serp belt
could be a bearing water pump or idler pully
if internal only could be something caught in the air vents
Oct 12, 2016 | Saturn Cars & Trucks
Goodmans troubleshooting
Hi;
You don't mention the fan. It is at the top of the condensing unit and should be running whenever the compressor is running. The water is doing the same ob the fan does, removing the heat from the refrigerant . What led you to put water on it?
Jul 30, 2014 | Goodman Manufacturing Goodman GSX130481...
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
I have a 2004 Olds Silhouette and the air conditioning isn't working. When I turn it on, I hear a faiint, high pitch whistle but the air doesn't cool. I tried to add coolant with one of those kits with...
Sure a back yard DIYER can do it , you just need to learn how the system works ! Is the A/C compressor kicking on when you turn it on ? Watch this The Trainer 40 When the compressor won compress Plus check out someother videos .
May 11, 2017 | 2002 Oldsmobile Silhouette
High pitched whining sound
sign of worn bearings? IF THIS IS THE PROBLEM IF WILL STOP WHEN IT DOES AND OTHER THAN GIVING THE UNIT PROPER CARE THERE IS NOTHING YOU CAN DO OTHER THAN REPLACE THE COMPRESSOR.
SOME COMPRESSORS WILL BE LOUDER THAN OTHERS AND RUN FOR YEARS.(ITS CALL A HARD STARTING COMPRESSOR)
ALSO THIS MAY BE THE NORM?
BUT IT IS PROBABLY THE UNIT NEEDS CLEANING (ALL COILS AND THE FILTER).
THE CAP. MAY BE GOING BAD NOT HOLDING THE CORRECT VOLTAGE TO THE COMPRESSOR IT NEEDS.
THANKS FREDDY ,LET ME KNOW IF I CAN HELP MORE!
Feb 14, 2010 | Heating & Cooling
Whistling noise while driving
If it is whistling while you rev your engine (while parked), then most likely there is a leak or hole in your air intake or vacuum hoses.
Facts:
1. Your car creates a vacuum to constantly receive air from the outside.
2. A whistling noise is created when air travels through a hole.
Check all air pressurized ducts for holes or leaks.
Check air intake system for holes or leaks.
Jan 08, 2010 | 2000 GMC Jimmy
My car is making a whisling sound when started.
hi ,,two things 1- water pump. but most likely check your pulleys they will make that high pitch noise one of them fixing to go bad and what will happen the belt will jam and jump lose and will lose all power ,,cause you have one belt for alt and the water pump mostly its the pulley right under the alt ,,hope this will help ....Joe
Aug 04, 2009 | 1996 BMW 318
Heating & Cooling Logo
428 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
