Question about Thermador Dishwashers
Water coming in dishwasher hours after wash cycle completed.
In between use, 1-2" water backfills the bottom pan of the dishwasher, sometimes even enough to spill out ouer the front edge when the door is opened. The water is not from dirty dishes draining. After the wash cycle completes, there is no water in the bottom. Why is water coming back in?
  • rombult May 27, 2010
    I have no other appliances hooked up to the drain. Is there some sort of switch accessible from inside the diswasher that I can check, that keeps water from coming back through the drain into the dishwasher?
  • Thermador Master
  • 2,605 Answers
Hello, Welcome to Fixya ! You've come to the right place. The problem you're experiencing sounds like (unfortunately) a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. Unfortunately I've seen some pretty serious damage over the years in extreme cases when left unchecked for several days...or longer. You may want to call in a pro however, the part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic.com, apwagner.com etc. Do a search for part # 1105846 at repairclinic ( that is their part # not B/SH/ ) you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch, just turn off the power, the water, access is gained through the kick plate/toe panel below the door. The valve will be on the left and involves only removing 2 screws, the water line in & out and 2 wires which go on either way...they aren't polarity specific. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Good luck. Macmarkus :)
Posted on May 27, 2010
  • 909 Answers
If it drains, it means pump is ok. Possible cause is" do you share a drainage area with another appliance ie washing machine? Try running it alone if so. Another possible cause is the pressure switch could be restricted and the connecting pipe onto the pressure pipe needs to be pulled off and blown into.Once cleared retry.
  • Terence Fourie
    Terence Fourie May 27, 2010
    Never knew the full complaint untill second part. If water is still finding its way into machine much later, it will almost certainly be the water inlet valve that is problematic and is not totally sealing off completely. Quickest way to check. is when finnished using machine, turn the water supply off and see if water stops entering the washer. If so, your valve needs to be replaced.
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
My questions relate to GE Triton DW Model GSD 6660 G00SS My problems are multiple. I have run the diagnostics and all functions seem to be working but two conditions during operation remain a...
After you the drain to discharge the remain water and the tub is visibly dry of water,then you open and load it do you see standing water after you have drained and know it was gone??
If that is the case what i believe your trouble is that where the dishwasher drain connects to disposer under the sink the drain hose is only leading from that nozzle downward,if that is so what is happening is the dishwasher is draining ok but backfilling whenever water runs through the sink. To fix that use a string on plastic zip tie and attach a portio of the drain hose so at one point the drain hose under the sink is higher that the nozzle and water in the sink will longer run into the hose and run upward since water is only going to drain down and wont ever rise on its own.The drain pump is powerful enough to push the drain water up that "HIGHLOOP" very easily.
Good luck i hope this has helped you to fix your dishwasher,
Gene
Aug 08, 2011 | Dishwashers
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
The dishwasher runs for 1 1/2 hours on the wash cycle.
This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
I know this may not have been what you wanted to hear but it is how they work today.
May 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Whirlpool Dishwasher GU3600XTSB 3 - 4 hours to complete washing
Wash time is determined by the cycle you select, the incoming water temperature and the installation location. The new machines will heat the water to a predetermined temperature and it takes roughly 1 minute for each degree of rise, If the incoming water is at 120 deg and the wash cycle wants 165 than it will take 45 minutes just for that one cycle to complete, Factor in an outside wall with poor insulation or lower water temperature and it could take even longer. Eric
Dec 30, 2009 | Whirlpool GU3600XTS Dishwasher
Dishwasher is draining during the wash cycle, but leaves water in the bottom at the end of the wash. What could be the problem?
Hello Ellsaesser,
Dishwashers typically leave water in the drain system exitting the pan but not a lot of water. If yours does then make sure you clean the drain screen ( normally located in or around the drain tube exitting the pan of the dishwasher..) If after cleaning that and after a normal wash cycle you continue to have significant volumes of water in the pan, the pump, lines leading to and from that pump may be restricting flow or damaged.. Those are a few of the normal culprets for why there is a lot of water in the pan of dishwashers after a cycle.. Hope that helps you identify the problem and resolve it,..,
Regards
Nov 29, 2009 | Frigidaire Dishwashers
Poor washing quality and water left in the filters ets
My friend, that siemans is a night mare to open. Just done one recently. Anyway, looking at it simply, i would suggest you check the inlet water filter. if water is slow to come in it will cause this problem. Remoe the water pipe from the solonoid and look for sieve. clean it well retry.
Sep 21, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The washing cycle takes 2 hours to complete
Make sure the sani cycle is not selected, or pots and pans, also with the dry cycle most will take about 2 hours, if your dishes are not that dirty use the short cycle. Be sure your water is at least 130 F. Run hot water at faucet before starting the machine.
Feb 27, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
Dishwashers Logo
Top Thermador Dishwashers Experts
ray gallant
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
