Question about Peg Perego 12 Volt Rechargeable Battery
Where can I find a replacement battery in Melbourne, Victoria, Australia for my sons Peg Perego jeep 12 volt
    Genius:
  • Peg Perego Master
  • 1,508 Answers
I could ship you one from here, but the shipping might be pretty high
Posted on Jun 07, 2012
  • 60 Answers
SOURCE: 12 volt rechargeable battery
Walmart has them> I would definately buy from them because if you get it home and then find out that you  have other problems than a new battery, you can always take it back.
Posted on Mar 11, 2009
  • 156 Answers
SOURCE: Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
Posted on Jun 03, 2009
  • 19 Answers
SOURCE: my sons peg perego john deere jeep only sets off
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
Posted on Jun 09, 2009
  • 156 Answers
SOURCE: Peg Perego Gaucho Rock'in Worked for a minute than Stopped.
it sounds like a fuse is cutting it off.
I would contact the repair help at
They always help me with my repair problems.
hope this helps
Posted on Jul 20, 2009
  • 8 Answers
SOURCE: peg perego battery charger
Normally, you would need to charge overnight- 12 hours.
Posted on Aug 04, 2009
How to change battery
you need the thing that connects to the battery and plugs into the wall. You can get one at walmart for around $40 Peg Perego 12 Volt Quick Charger for Peg Perego John Deere Polaris and...
Aug 01, 2014 | Peg Perego 12 Volt Rechargeable Battery
We have a Peg Perego John Deere tractor that won't go. We've tried recharging the battery but it still doesn't work. The last time it was used, my son was repeatedly pushing the accelerator...
check the battery with a multimeter and make sure you are getting at least 12 volts, if its not showing any voltage one of the wires from under the plastic housing has become disconnected, if it is showing voltage but not 12 volts recharge it then check it again after about 12 hours and make sure it is showing 12 volts, if it isn't check your charger with a multimeter and make sure that its putting out at least 13.8 volts, if it is then you have a bad battery
Jul 15, 2011 | Peg Perego John Deere Gator HPX Ride on...
Where can i buy a 12 volt charger only in victoria, Austalia.
you can order aftermarket ones off of ebay for pretty cheap or i can ship you out one
Oct 11, 2010 | Peg Perego 12 Volt Rechargeable Battery
HI, I HAVE A PEG PEREGO JOHN DEERE LOADER.I NEED A
You can get compatible replacement batteries for your ride-on toy from here.
John Deere Ground Loader Peg Perego Ride On Toy Battery 12 12 AH F2... You can just change the battery and use the plastic casing and wires attached to your current battery. This will save you a nice sum of money. It is not hard to do. Check this video to see how to do it.
Oct 03, 2010 | Peg Perego 12 Volt Rechargeable Battery
Peg Perego Apache Jeep electrical problems.
start at the battery, then check the foot pedal then the shifter switch
Jul 14, 2010 | Peg Perego John Deere Gator HPX Ride on...
We just replaced the battery and it worked fine
Use a meter to confirm whether the battery is still working. The meter should read around 12-13 VDC if the battery is good. The 12 Volt Peg Perego battery is made with 2 6 volt batteries connected in series. Maybe the connection broke when the battery fell out. Check the connection and also check with a meter if either battery is pumping out 6 volts.
Jan 01, 2010 | Peg Perego 12 Volt Rechargeable Battery
I need a new batery charger for my peg perego gator hpx 12 volt. where can i get one?
I bought my Peg Perego Charger at
http://www.shopjandl.com/mecb0034.html
They fit the 12 volt blue batteries for Peg Perego.
Hope this helps
Jul 09, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego 12 Volt Rechargeable Battery Logo
96 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
