Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Question: Does the igniter stay on all the time the oven is on?
    President:
  • 949 Answers
With hot surface ignition (glow bar) the ignitor will stay on when ever the gas is burning.
Posted on May 28, 2010
Testimonial: "Thanks for your help"
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Replaced igniter. Is it suppose to stay on the whole time the gas oven is on?
I assume you are talking about a glow bar type igniter. Yes they stay on as long as the burner is on but will cycle off when the oven reached the set temperature then come on to light the burner again when the oven cools back down to maintain the temperature.
May 10, 2015 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
The oven igniter stays on and won't shut off what part do I need to repair this ? 20 " gas unit
When the oven is ON, the igniter should stay on.
If the oven is OFF and igniter stays on check the sensor assembly and or flame sensor for continuity.
Jan 04, 2015 | Danby 20"" 4-Burner Gas Range with Oven...
When trying to light my oven, it take more than 5 times igniting it for the oven to work, I do keep the door open and have to watch to see if the flame comes on. Sometimes the flame comes on, but doesn't...
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 06, 2010 | Bertazzoni X30 4 GGV X Gas Kitchen Range
Just replaced the igniter in my maytag gas oven. Before I replaced it all was fine but since the replacement igniter was installed oven stays on all the time. I have to unplug power so igniter will turn...
Your oven switch or control has failed. This is the only way power can get to the igniter. Sometimes this is the cause for the igniter failure like the previous one you had. Could have fried it out pretty quick.
Apr 09, 2010 | Ovens
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Glow plug on oven
Yes. Igniter stays on from just before ignition until just prior to burner shut down with each burn cycle.
Nov 12, 2008 | Tappan 30IN ELEC IGNa Oven
Oven Ignitors
The igniter will remain on because it controls the gas valve.
Jun 03, 2008 | GE JGRP17 Gas Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
209 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
