Question about Dell Latitude E5500 Notebook
I am using Dell Latitude E5500 at home, I am unable to connect to internet. But Wireless Network is connected and having good strength
  • family348 May 27, 2010
    Do you have other devices that are working on this wireless network that are connecting to the internet?
    Sergeant:
  • 356 Answers
Try to uninstall and reinstall your Local Area Network driver by going to the device manager from the control panel. expand the network adapter and right-click your LAN then select uninstall. Restart your computer and windows will automatically reinstall your LAN driver.
Posted on Jun 03, 2010
How to turn on bluetooth on Dell latitude e5500
To help you turn on Bluetooth on the laptop, please follow the instructions as mentioned below:
-Find the wireless switch, located on the front of the E5500 to the left of the touch pad.
-Slide the wireless switch into the 'On' position to enable wireless radio communication on the Latitude.
-Now click on 'Start' then click on 'Control Panel'.
-Select 'System and Maintenance' and then click on 'Device Manager'.
-Now double click 'Bluetooth Adapters'.
-Right click the 'Bluetooth driver' and then select 'Enable' from the context menu, if available.
-Navigate to the Dell Support website in a Web browser if the Bluetooth Adapters category is not listed in Device Manager.
-Click 'Start Here' and then click 'Drivers Home'.
-Click 'Choose from a List of All Dell Products' and then click 'Continue'.
-Click 'Laptops' and then click 'Latitude' now select 'Latitude E5500'.
-Choose your operating system from the associated drop-down menu.
-Expand 'Network' Click 'Download File' next to the Bluetooth driver, then click 'Download Now'.
-Launch the EXE file when the download completes. Follow the on-screen instructions to install the Bluetooth drivers to the computer.
-Restart the computer after completely installing setup for using Bluetooth on the E5500.
GuruAid.com
Mar 21, 2016 | Dell Computers & Internet
I'm having problem connecting to the wirless internet on dell lataqitude e5500. The wireless is on but im unable to connect to any wirlesss networks? Can this problem be solved?
If you are using a firewall disable it there is a wireless toggle switch on the side of your laptop. It slides back and forth to turn your wireless card on and off. It has a little wireless symbol next to it, and you should NOT see red. If you see red showing, it means that the wireless adapter is turned off. Slide the adapter to the ON position, and then try to repair your wireless connection. Hope this helps
Sep 01, 2011 | Dell Latitude E5500 Laptop
I dont have internet. my PC can't find wireless connections it says something about hardware.. where can i find it?
It's likely that you need drivers for your wireless network adapter. This is definitely the case if you just reinstalled Windows.
1. Go to the Dell support sight at this link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&SystemID=LAT_E5500&catid=-1&impid=-1
2. Select operating system.
3. Click the down arrow next to Network.
4. Click Download in the row that's named Dell Driver, 6/17/2010, 5.60.48.35, A36.
5. Download the driver and run it to install wireless drivers.
6. Restart computer.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 30, 2011 | Dell Latitude E5500 Notebook
I have a Dell Latitude D600. I can connect to the internet if my computer is plugged directly into my modem. When I disconnect from the modem and try to access the internet using wireless, I can not...
Your computer may be picking up the wireless networks in your area including yours but you still require to configure your computer to the router for which you will require to go through the manual which came along with the router/modem. If you are a computer savy man you can do it yourself otherwise you will require services of technical person.
Feb 11, 2011 | Dell Latitude D600 Notebook
I can't find the wireless switch on dell latitude e5500
Go to the start menu and click where it says run or type in right above the start button in the white field and type ncpa.cpl then push enter. Where it says wireless network, right click on it then click enable. If needed, right click again and view wireless networks or Connect/Disconnect then connect to the wireless network. Also there could be a tiny switch on the right side of the computer where you turn on the computer, there might be a button to click to turn it blue. Hope this helps
Sep 30, 2010 | Dell Latitude E5500 Laptop
Dell latitude cp laptop how do you make it wireless for the internet
All laptops have inbuilt wireless network cards. You would need to have a wireless access point which has internet connectivity at your home or office. If available, you need to search for the wireless network and get connected. Some networks are secured so you would have to contact the administrator for the key.
Jul 22, 2010 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Brand new Dell netbook won't connect to internet (at home). Connects fine at work. Wireless strength is good at home but no internet connection. Husband's notebook connects just fine so it appears to be an...
No, it's probably because you have setup a wireless home network with security in place.
Go through the settings on your husband's notebook settings for your home network and set your Dell up the same way. You will need to know the SSID for the wireless network, security type and key to set it up.
Oct 28, 2009 | Dell Computers & Internet
Unable to connect to Wireless Network Connection (DELL D600)
could you open the command prompt and type ipconfig and tell me what you get..
Oct 08, 2009 | Dell Latitude D600 Notebook
New Laptop Will Not Connect
The first thing u need to do connect ur router to the computer with a wired connect access the router page (firmware) ip address which need to enter to open the same on internet explorer is 192.168.0.1 enter the user id & password of router (default user id & password is admin or password)
step 1 go to wireless change the channel to 6 (this the best channel)
Step 2 go to add/remove in control panel remove the dell wireless utility
step 3 go to device manager in control panel go to network adapter right click on wireless network adapter & select uninstall or remove
step 4 Now click action on top of device manager & click on scan for hardware changes it will reinstall the driver
Step 5 now go to network & sharing center go manage network connection right click on wireless network connection & select the connect it will show the list of wireless network now connect to ur network enter ur security key once ur connected save the network & ur issue is resolved
Jun 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Dell Latitude E5500 Notebook Logo
256 people viewed this question
Alun Cox
