Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The center part that adgitates does not rotate as i think it should can i tighten it somehow
  • Whirlpool Master
  • 1,606 Answers
You need to remove the screw from the center of the agitator and pull up on the agitator from the bottom , to remove it . Seperate the 2 piece agitator , and replace the 4 agitator " dogs " . Reasemble . The " dogs " lets the top section of the agitator only move in 1 direction causing the clothes to " tumble " . OR , take the complete agitator to a parts house and they will install them for you .
Posted on May 27, 2010
Somehow my screen got rotated where everything is sideways have a hp windows 7 wirelesss touchscreen
I imagine you might have Intel powered graphics.
Here are their detailed instructions on how to rotate your display through various methods:
I think you will find your solution there, at a guess I think if you press CTRL+ALT+UP-ARROW it should bring your screen back to normal orientation.
Graphics Using Screen Rotation With The Intel Graphics Control Panel
Mar 20, 2014 | Televison & Video
My kenmore 70 series will not agitate. It rocks back and forth but center doesn't move. Now if i put my hand on the top of it and press it down it does just fine. Is there a gear that may be broke in the...
Not a gear, Four peices of plastic.  They are about $2 and really easy to replace.  Take the cover off of the top of the adgitator with a flathead screwdriver, and there will be a bolt underneath it.  Take the adgitator off, and seperate the two halves.  There are four pieces of plastic known  as dogears because of their shape.  Replace those and it will work
Dec 04, 2009 | Refrigerators
Somehow, she added water to raise the amount of water in a bosch front end loader and it overflows when adgitating. how can I manually remove water?
take the drain hose at the back and lower it so its beneath the water level in the drum--the water should flow out--or else open the filter at the front--but thats a bit messy
Nov 16, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
What should i torque the head bolts to on a 2001 ford 3.0litre engine?also the torque for the intake also!?
for a 3.0 2v....new head
    1. Install the bolts.
    2. Tighten the bolts in five stages in the sequence shown.
    • Stage 1: Tighten to 50 Nm (37 lb-ft).
    • Stage 2: Loosen the bolts one full turn.
    • Stage 3: Tighten to 30 Nm (22 lb-ft).
    • Stage 4: Rotate each bolt 90 degrees.
    • Stage 5: Rotate each bolt an additional 90 degrees.
  • intake bolts are:
    1. Install the intake manifold. Tighten the bolts in the sequence shown in two stages.
    2. Stage 1: Tighten to 15 Nm (11 lb-ft).
    • Stage 2: Tighten to 32 Nm (24 lb-ft).
    • work from the center out
  • Jul 07, 2009 | Ford Taurus Cars & Trucks
    I have a Grohe Europlus Kitchen faucet. The base
    there is a couple of plates with a little screw in the center that tightens up the plate got to tighten it up
    Jun 23, 2009 | Plumbing
    Adgitator removal
    Just follow these steps:
    1. Remove the center dispenser from the top of the agitator. It should just pop off.
    2. Locate the white plastic cap underneath and pull straight up to remove.
    3. Locate the agitator bolt underneath and remove using a socket and ratchet (can't remember the size). Hold the agitator still with one hand in order to loosen the bolt.
    4. With the bolt removed, grasp the agitator by the bottom flanges and pull straight up. It should lift off the center post.
    NOTE: Sometimes these agitators will stick due to years of detergent accumulation. You may have to wobble it back and forth to get it loose.
    If you have questions, please let me know. I hope this helps you.
    May 03, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
    Loose replacement blade
    I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
    Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
    Need to replace the adgitator dogs
    Nothing else needs to be removed. place the agitator on the floor, step on the sides of the bottom of the agitator, grab the top section of the agitator and pull, the sections will separate. hope this helps.
    Aug 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    120 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
