My t v sony tritron when I swicth on the picture doesnt appear but sound is o k . Please let me know what could be the problem.Any service station in bannerghatta road or near by?
    President:
  • 1,099 Answers
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
Good luck...
Posted on Jun 01, 2010
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
It doesnt give quality pictures. meaning some lines appear when t
The problem is of CCD Imager, It needs Replacement. In some models Sony replace CCD imager free of cost, Please contact any nearest Sony service center for free replacement of CCD imager.
Thanks.
Apr 25, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
The top half of picture is completely back, please
you have a vertical problem it could be a cold solder joint on the vertical out put ic or a component failing in the circuit
if you have the tools a soldering station and some know how you can fix this
or you may want to contact a local for help with it
Nov 09, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Vertical red lines apear on Sony XBR after Roku install
try re-botting your HDbox,also refit your scart lead to your box & t.v.
If you drop me an e-mail I will go through how to re-bot your box,if you don't know - re-botting your box helps pull in all the new software for your box - think it like a pc needing to update the programmes.
e-mail add.pbviewingsky@yahoo.ie.
Aug 07, 2009 | Televison & Video
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
No sound tv
Sounds like the SBX module s bad. There is a bypass modification that wil repair this problem oryou can finda replacement modle at tritronics for around 30.00 but it will need to be solderd in or you can do the bypass mod with 2 .47 uf capacitors from Rado shack for about a dollar.If you need any additional info please let me know.
Feb 14, 2008 | Televison & Video
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
No picture
No you cant fix it! its due to your CCD lens not working! it needs to be repaired at Sony Authorised service station
Dec 08, 2007 | Sony Handycam CCD-TRV108 Camcorder
i have a new hd tv i have sound but no picture from with a indoor arieal what can do to check it
Dec 04, 2007 | LG 42LC2D 42 in. LCD HDTV
RCA Home Theatre Wide Screen TV Model# P52731WK
This sounds to me like the parameters are off, I recomend only a service tech adjust this for you because the parameters can only be accessed by a service man, and they are critical, if done wrong the whole set can go out of wack.
Aug 15, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
Top Televison & Video Experts
