Question about Freezers
Blauknecht freezer stopped freezing!
I have a blauknecht freezer. The freezer has stopped working and the alarm light is on. Where should I look to fix it?
    President:
  • 1,561 Answers
1.check temperature setting
2.Clean condensor coil.
3.Unplug the freezer, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat.
4.Test temperature control.
5.Test the evaporation fan.
6.Test the defrost timer.
7.Test the compressor relay
8.Test the overload protector.
9.Test the compressor motor.
These are the areas you are to look to solve the problem.
Take care.
Posted on May 27, 2010
  • Sulaimon Jimoh Olayemi May 27, 2010
    Open the containing box and check to see if the fan blades are intact
    and unfrozen. Use a hair dryer to defrost the fan or use some oil to
    loosen up the fan and see if that solves the problem.
    Make sure the ice maker is running properly. The ice maker is one
    component of a freezer that malfunctions frequently, because the valve
    strainer gets clogged. To clean it, unplug and disconnect the freezer
    unit from everything and take off the water line where it goes into the
    valve. Take off the strainer and clean it with soap and water. Put the
    unit back together and see if the ice machine works again.
    Locate the condenser fan at the bottom of the refrigerator and see if
    the drain hose is damaged in any way. It is simple to replace the drain
    hose, and the part is inexpensive. If there seems to be water leakage
    under the fridge, check to see if the drain pan is broken or overturned.
    When the freezer is defrosting, sometimes the drain ports located at the
    bottom of the freezer unit get clogged. Unclog the ports using a small
    wire or solid object that won't break off inside the port. Never use
    wood, as this might break inside the drain ports and cause a bigger
    problem.
    Take care.
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
My frigidaire freezer is not freezing....the hi temp light is on. The model # is LFFU17F5HWH.
is the unit running, can you hear the compressor , it the freezer fan running check to make sure no wires have been pulled off
Apr 22, 2014 | Freezers
The temp on my freezer is on normal and was working ok then just stopped and the red light is on turned up the temp to make it colder and the fast freeze but not working and everything is defrosting
Hi Denise, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will typically sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards!
Sep 24, 2013 | Frigidaire 13.7 cu. ft. / 388 liter...
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
How to stop alarm of freezer
Unplug it for about 10 minutes to allow any capacitors to dissipate. Switch back on. If alarm starts straight away, suspect faulty controller, probably caused by the spike in the power supply
Apr 18, 2012 | Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
32 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
