Question about Vizio SV470XVT 47 in. LCD TV
Purple hue and no sound
The tv is about two years old and hooked up to Direct TV for HDTV.
The color purple is dominant on the screen and there is no sound.
  • Vizio Master
  • 8,457 Answers
Ur tv Tuner board,that the board where the incomming brocast signal cable connect to it.That the Tuner board,it defective.Replaced the Tuner board ur tv will functions normal again.
Posted on May 27, 2010
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Dynex 32 lcd hdtv L32-10C color is flashing green and purple
Just go to the service center where you bought that tv ,cause its ,one year warranty period. just consult your tv to the costomer service personel.
Jun 28, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Dropped tv and now i only get purple and yellow as the tv colors
hi..It sounds like your tube Shadow Mask may have got
magnetised and need to be degaussed.turn off your TV
at the mains and unplug it for at least two three hours,
after that time power up your TV it should degauss the
tube at power up.
try this out..
thank u..
kindly rate my response..
May 06, 2009 | JVC AV-36260 TV
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Colors are messed up
the deguasser in your tv may not be working right..or the magnets in the corner of your tv has moved....it can be manually deguassed but a tv shop would have to do it..
Jun 28, 2008 | Sylvania 6427TE 27" TV
SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Vizio SV470XVT 47 in. LCD TV Logo
665 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
