Question about Compaq Presario 5000 PC Desktop
I can't view internet videos CPU Compaq,Windows 2003
  • family348 May 27, 2010
    Could you clarify what you mean by internet videos, do you mean like youtube?
    If you could also advise on what web browser you are using, eg. Internet Explorer?
  • naimanjoseph May 27, 2010
    google
I can't able to download file or view file from internet.as long as i start it my laptop automatically shutdowns.plz guide.
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Jan 07, 2013 | HP Compaq Presario v3000z Notebook
I have a Proliant HP DL580 G4 that had its system board replaced. The OS (Windows 2003 Enterprise) now only recognizes one cpu core. The server has 4 dual core cpu's. How can I get the OS to see all 8...
You may need to check your BIOS to make sure the multiple CPU function is enabled. Once it is, a reboot should correct this for you.
Good Luck
C2Solutions
Sep 08, 2011 | HP Compaq ProLiant DL580 G4 (430811001)...
I have a compaq presario 7478, when I got it, the cpu already had windows xp on it, so I recently reinstalled windows xp, and I can not connect to the internet because I am missing the ethernet controller...
You can download the drivers from the Compaq/HPWEB support/download page. Make sure you select your model computer/laptop and the XP Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 04, 2011 | Compaq Presario 7478 PC Desktop
I have this old laptop and its called a compaq (presario 2500) well yesterday i brought the sims3 game for it because the laptop dosent have internet. When i installed the game it says windows xp has to...
Thanks for using fixya.
My name is Carlo.
Your computer might not pass the system requirements that's why it has an error. Or, you can try installing it one more time and check if it will work. Computers do mess up sometimes.
Here's the system requirement of SIMS 3:
Desktop PC (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1 GB of RAM
GPU: 128mb Video Card (GeForce FX 5900 or Radeon 9500)
Desktop PC (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 1.5 GB of RAM
Laptop (Windows XP + SP2):
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
RAM: 2 GB of RAM
Read more: http://pc.ign.com/articles/939/939410p1.html#ixzz10TQHijZi
IF your computer does not pass the system requirement, then you cannot play sims3 in your computer.
I hope this helps. Thank you for using fixya
Please leave your comment and ratings. Thanks
CARLO
Sep 24, 2010 | Computers & Internet
Need new vid card
The Compaq s3200nx comes with integrated video; Via KM266 graphics. It has:
Available slotsTwo PCI
AGP4x 1.5v
AGP is for Video but nothing else and it must be 4v. PCI is for all types of cards including Video.
You can get a PCI Video card with more memory on it than your current video.
You must verify your monitor connection. Is it VGA? or DVI? Make sure the card has the right type of connection.
May 06, 2010 | Compaq Computers & Internet
Will not display windows XP from a Compaq tower with a Sempron 3500 cpu. Is the vidio card on the cpu too powerful for the monitor?
If the monitor has power, and is turned on, there should be a display. Have you checked your video driver? Do you have another monitor you can connect your computer to? If so, go to My Computer, right click, on the menu click on properties.
The look for the hardware tab and click on device manager. See if any of the devices are showing a trouble icon, especially the monitor and video areas.
You can download your video driver from the compaq support website if you need an updated driver.
Apr 08, 2010 | Compaq MV 500 Monitor
A compaq cpu refuses to boot,what is the problem?
Thats your product key to install/reinstall windows. I wouldnt share that on the internet. :)
Mar 26, 2009 | Compaq (351051-b21) Xeon MP, 2.7 GHz...
CPU Usage High
press ctrl+shift+esc. Click processes , then select view all processes. Find out which one is using the resources. Then press windows key+ r. Type msconfig. And disable the program.
Jan 22, 2009 | Microsoft Windows Vista Ultimate Edition
Upgrade processor?
I read the thread over at computing.net just now. I'm having trouble locating a picture of the internals of the Deskpro 4000 online but I know Compaq did some pretty non-standard things back in the day.
Yea, try upgrading the processor - it's not going to cost much to try. Much as WebsWonder commented, I've been throwing out everything below 2ghz at work.
The 2mb S3 Graphics was great for its day. Look around on eBay and find a PCI interface card with 8 meg of ram or better. An ATI 7000 series would be good n cheap but even a Rage 128 would be an improvement over what you have now.
I honestly don't know if upgrading to 333 mhz is going to produce smooth video for you. I upgraded my son's Compaq Armada 1750 from a P-II 333 to a P-III 500, bumped the memory up to the max 312, and installed a 7200 rpm hard drive. It streams video just fine on XP Home.
Nov 11, 2007 | Intel Pentium MMX , 233 MHz
Compaq Presario 5000 PC Desktop Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
