Question about Frigidaire FTF530FS Front Load Washer
Front load washer FTF530FS1 stop mid cycle, sometimes for more then an hour, then starts up again, entire cycle can take more then 3 hours? Also during cycle is very loud.
  • Frigidaire Master
  • 909 Answers
Seems you have possibly 2 problems. One, check to see if the element is not faulty. If no heat during heating cycle, the washer wont proceed for a long time.. Two, if noisy, especially on spin cycle, the bearings (2 of them) and the seal are faulty. Replace them as soon as possible.
Posted on May 27, 2010
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer gives off hot smell and won't finish a cycle
thanks..then it's the board, not the guts of the system
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
I have an LG front load washer (model# wm1814cw). The machine stops mid cycle but gives no error code. I have to almost unload the washer entirely and then restart the cylce. If I try to begin the
Replaced the sensor and it rocks again. I was about to buy a new washer.
1. Remove the back panel
2. Remove the center bolt that hold the cap which covers the motor coil.
3. Pull the cover out.
4. Remove all the bolts that hold the motor coil. Be carefull not to drop the coil when you take the last bolt out.
5. Remove the old sensor and replace the new one.
6. Put back every thing and it will rock again.
Jul 22, 2012 | LG WM1814CW Front Load Washer
My 4 year old front load GE washer won't go to the
is there water left in the lower area below the lower wash arm?if so maybe the bottom sump is blocked by food debris or the pump and or sump is blocked by food debris shutting the unit off earlier than the cycle says,find the tech sheet and run the diagnostics for the entire cycle,its normally in the lower area below the door in this panel on one of the side walls in an envelope
Jul 25, 2010 | GE Washing Machines
Calypso washer will not start.
Now it looks like electronic micro controller problem. This sort of erratic functioning takes place due to corruption in the programme memory.
Contact the manufacturer's service center and obtain the right one and make them fix it. You will be covered by guarantee also!
Apr 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
No lights on panel, door won't open
This is for the Whirlpool/Kenmore HE2 Plus:
1 Unplug/Disconnect the washer
2 Remove the lower kick panel
3 Reach up along the inside of the front & locate the bottom of the door switch/lock unit.
4 Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5 Gently pull the tab down about quarter inch or until a click is heard. Gently open door.
Apr 11, 2009 | Kenmore Washing Machines
Whirlpool Duet Washer - Problems with the Spin Cycle
you might want to call whirlpool cause it might be still in warranty
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
284 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
