Question about Jandy Lite2 LJ125 Ceramic Gas Heater
Jandy Lite 2 LJ Water Leaking
Water leaking when pump is on. Looks to be leaking from right corner of heat exchanger. I did not remove exchnger yet. Can I get parts
    Top Expert:
  • Jandy Master
  • 6,394 Answers
Or possible bad heat exchange as copper tubes erode they shrink from seals and leak maybe bad exchange if tubes are sharp on edges replace exchange
Posted on Dec 03, 2017
I have the same problem, removed the heat exchanger and found a small rubber gastket that was ripped. The gaskets can be found at parts store. Set of 18 about $20.00.can.
Posted on Jun 01, 2010
LLD125 pool heater leaking water from inside
My heat exchanger was cracked. I found an old welder who knew how to weld the cracks for $100 vs $900 for a new exchanger,. Also ordered replacement seals for the 2 chambers. I used high temp automotive engine sealant as an additional sealant precaution. Also inspected tubes and cleaned corrosion. Works fine last 3 years. Takes some mechanical skills.
May 18, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater leaks water on lower left side (side where gas attaches) towards rear. Do not want to take totally apart to get to leak. Side does not appear to come off.
The heater sides do come off. Your heat exchanger will be what is leaking. Some people (I have never tried) have had them welded at a local radiator shops with some sucess though it is likely the heat exchanger will have several thin areas likely to fail in the near future if you have a leak now.
New heat exchangers are expensive. If you would like a quote, contact us with your heater model and serial number at www.arrowpools.net.
The longer you leave it leaking, the more likely you are to damage other parts down in the bottom of the heater so it is not something you should let sit. If you are going to go without it for a while, close the water off if you have a bypass. Otherwise, consider having the plumbing re-arranged to bypass the heater.
Oct 08, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Water leaking from rubber gasket on tubes in heat exchanger
Are you sure it isn't just condensation? A leak will not go away. If condensation, nothing to worry about. It will go away.
May 27, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Feb 21, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Jan 23, 2009 | Jandy Digital Lite2 Lj325 Btu Heater,...
Jandy Lite2 LJ125 Ceramic Gas Heater Logo
255 people viewed this question
Top Jandy Heating & Cooling Experts
Willie Burks
Willie Burks
Level 1 Expert
David Spradling
David Spradling
Paul Carew
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
