Question about HP OfficeJet d145 InkJet Printer
Expired ink cartridge
The printer keeps telling me the black ink cartridge is expired even though changed the black ink cartridge with a brandnew one.
  • GBear99 Jun 26, 2008
    I have the same issue ("supply expired ...."). It seems to refer to the black cartridge which I changed after several weeks of "low ink" message. I had to change the color too, but that doesn't seem to be causing an issue. I've tried turning off, replacing the cartridges (with and without power on), even powering up without them then re-fitting them. This message doesn't seem quite the same as the normal out-of-ink message. Could it be the "used ink container"? The manual doesn't say how to empty that,
  • jhenson Aug 24, 2008
    I get an error message saying "expired cartridge" even for scanning.  I wonder if there is an expiration date on ink cartridge that the machine detects.
    Problem Solver:
  • 12 Answers
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
Posted on May 14, 2008
SOURCE:
I have two expired color cartridges in my D7160. I only need to print in black,and have a brand new black cartridge inserted. The printer keeps telling me to replace the expired color cartridges, yet I...
They believe expired cartridges will damage the printer. If you change the date back on the printer and computer this will solve the problem and allow you to print.
Regards GM
Please rate this answer below Thank You for supporting the Fix Ya Community
Apr 17, 2011 | Office Equipment & Supplies
Bypass expired message cartridge. Cartridge is less than six months old & nearly full.
Every cartridge will have its own ID and Expiry date, please check the Cartridge expiry date, if its really expired then printer will reject it even-though the cartridge is full.
We cannot bypass cartridge errors for single cartridge in INK-JET printer, because they work in TIJ technology (Thermal Ink Jet) which needs all cartridges to be functional unlike Laser-jet printers.
Regards
Riztech
Jan 13, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
I bought a black ink for my hp photosmart c5 180 and the when i turn on the printer it says the ink has expired. Can i still use it or will i damage my printer. Thanks regards Anita
Hello
according to HP
Each ink cartridge has an expiration date. The purpose of expiration is to protect the printing system and to ensure ink quality. When you receive an ink cartridge(s) are expired message, remove and replace the expired ink cartridge, and then close the message. You can also continue printing without replacing the ink cartridge, by following the instructions on the HP All-in-One or the ink cartridge expiration message on your computer screen. HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Device service or repairs required as a result of using expired ink will not be covered under warranty.
You can get more detail from here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00819032&dlc=en&product=1153481
Hope this helps, if so do rate the solution
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
Says Black ink supply expired. Installed new
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 10, 2009 | HP OfficeJet 7140xi All-In-One InkJet...
"Expired color cartridge" message blocks black printing - nothing works
Hello merelU. I'm afraid you may have to replace the empty color cartridge as there may be problems with the printer while an expired cartridge is installed on the printer (even though some of the cartridges are still under warranty) and also, HP cannot guarantee the quality or reliability of expired ink cartridges.
all the best.
thx
Oct 07, 2008 | HP Photosmart 3310 Printer
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
Hp printer 7110
hi,
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
adonscott
Jun 18, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Cartridge
Chances are the new cartridge is defective.
Check the expiration date on the cartridge, and even if it is not expired, I would suspect the cartrigde is bad, dried out, not allowing the ink to lower.
That is the most frequent issue with your problem
Feb 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet d145 InkJet Printer Logo
334 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
