Frozen keyboard - compaq cq 61
My daughter has a compaq cq 61 laptop and the keyboard is frozen, but the touch pad works along with the cursor on the screen, how can this be fixed,thanks.
  • 4,737 Answers
First of all please check the Fn key, you might have pressed it several times which disabled the keyboard or the cursor functions. Try pressing it several times again and check the effect. You can also check whether external keyboard is working or not. If at least your pointer (track pad) is working, open the control panel and go to keyboard settings and see if anything has been disabled or not. Verify that it is working fine in dos mode, you can do this by entering the dos mode during the start up. Good luck.
Posted on May 27, 2010
When I like to make a Xp Insaillation in my Computer Amilo li 3710, After booting CD Coming some blue screen error massage in my computer.
My cursor and keyboard does not work after bootup
You have to reinstall touchpad driver, because you deleted the driver.
Dec 26, 2011 | Computers & Internet
Comaq presario cq 71 cursor is frozen. PC shop man siad it was poor battery. Booted up from mains and cursor worked fine until recently. Mistakenly left battery in and powered down to hibernate. Now cursor...
yeah ..you have to disable the power saving mode..This is the only thing related with the battery usage that may disable the cursor..o r..just reinstall the touch pad..
to do that download its driver and run it into computer ..
here is the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3795238&
just select eh operation system and download the touch pad driver..
or go to control panel ..open the touch pad icon ..and in there select default settings ..or enable the cursor again ..if it is disabled..
if this is not working ..try reinstall it like I said ..It always starts a clean installation from the factory settings ..
Avoid hibernate it ..cause will always preserve the last settings ..just close it proper each time ..this way it will boot and recognize devices each time from the start ..
Dec 06, 2010 | Compaq Presario CQ50-215NR Notebook
My keyboard and touchpad cursor are both frozen.
Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties in control panel
Mar 18, 2010 | Toshiba Satellite A135-S2246 Notebook
How do you remove hp cq61 keyboard then refit, thanks
my daughter has a compaq cq61 laptop and the kepad has frozen, but the touch pad works,how can i fix this plse.
Feb 06, 2010 | HP Computers & Internet
Cursor frozen
have you tried installing a regular mouse?
also you can try going to the device manager and uninstalling the touchpad driver and then reinstall it.
Sep 09, 2009 | Dell Inspiron 1525 Notebook
FROZEN CURSOR
Sounds like the touch pad is not working anymore. try using a USB mouse and see if that works. also, see if you can reinstall the touch pad software to fix that.
Aug 28, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My Touch pad mouse doesn'e work
hi. if its a physical problem, try using a eraser with it and then clean the thing with the eraser. i do it on my my laptop and it works for me. so yeah.
May 20, 2009 | Compaq Computers & Internet
Eratic movement of cursor using touch pad
Sounds like you have a touchpad malfunction. If its an older laptop, I would recommend replacing it. Not worth the hassle of trying to install a new touchpad...
May 12, 2009 | Dell F3534 Touchpad
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Jul 20, 2008 | HP Compaq nc6220 Notebook
Computers & Internet Logo
482 people viewed this question
David Payne
David Payne
