Question about Nokia 3110 Cellular Phone
Nokia 3110c does not start
Sir, My Nokia 3110c handset does not work properly. It is turned off automatically when I started it.
  • Nokia Master
  • 4,737 Answers
There's no accurate solution for this problem with the model 3110c or 3110. Most of the times it's related to battery and it's connector, so first check your battery, battery connectors and make sure your battery is working properly. In most cases, this is solved after flashing. Good luck.
Posted on May 27, 2010
My nokia 3110c music player is not started after updating library
my nokia 3110c music player is not started after updating library
Sep 30, 2010 | Nokia 3110 Cellular Phone
Nokia 3110c shows phone restricted undo
NOKIA PHONE 3110C
START ON
RESTRICTION CODE
Sep 18, 2010 | Nokia 3110 Cellular Phone
3110 Cellular Phone: Sir pls send me Restriction code of Nokia 3110c ...
you can get your unlock code for your Nokia 3110c model mobile, through this site http://www.mobile-unlocker.com/nokia-3110c/rs2wp9/
It has the best instructions and easy methods for unlocking your Nokia mobile phones.............
May 14, 2010 | Nokia 3110 Cellular Phone
How to format nokia 3110c phone
sir i think the phone memory of my 3110c is full.. so when i press the power button to turn it on.. it hang.. i cant even type th code.. any sulotion sir?
thanks
Apr 15, 2010 | Nokia 3110 Cellular Phone
My nokia 3110c not working properly
Clean and dry the battery terminals, check if the battery has swollen which indicates poor battery, reset all the settings to factory default, possibility of bad memory cells (memory card), it seems the handset is still in warranty period, contact nokia customer care for free repairs or replacement.
Oct 08, 2009 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Changing the Fascia in a Nokia 3110c
sir my3110c when i was insert the 1GB mmc then handset was reastert automatic yyyyyyyyyyyyy   plz healp me
Oct 14, 2008 | Nokia 3110 Cellular Phone
NOKIA 3110C DOES'NT WORK WITH MEMORY CARD
Dear sir,
I have Nokia 3110c mobile.When i was insert memory card(micro sd 1gp),it was continuously restarting.So please give some solution.
Jul 16, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
174 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
